Anyone know how to test the starter motor on 2006 wr450f
Brand new battery, starter relay read good (I think) on the multimeter but have a new one arriving this week. Just curious if anyone knows of a way to check the starter motor before I break into it.
The previous owner “jerry rigged” some key ignition system to bypass the on/off button (which drives me crazy). I plan to remove it but am still learning the electricals as I’ve only owned 2 strokes.
Download a manual and all the info is there mate. I suspect brushes will be worn, quite common and cheap to replace. Don't forget to mark the starter body at each end against the end caps before you pull it to pieces. Clean up the commentator as well.
