nots0much Posted October 1, 2019 I'm thinking about having a stem and triples made to put CRF150R forks on the CRF150F. I wonder, if someone else has similar desires. Any non-OEM fork on any bike, really. I suppose brake adapters and axles would be possible, as well. 2 Share this post Link to post Share on other sites
ramz Posted October 1, 2019 Here's the process for the CRF230F: https://rickramsey.net/CRF230Fforks.htm But some riders are using XR400R forks now; much easier conversion, better performance, and cheaper. Probably overkill for the CRF150F... 1 Share this post Link to post Share on other sites
nots0much Posted October 1, 2019 I'm familiar with your resources. But I want a USD fork and CNC triples. 2 birds and all that. 1 Share this post Link to post Share on other sites
Chuck. My Rides (3) Posted October 1, 2019 There are CNC top triples available for the Show 37 USD forks used on the CR80/85, CRF150R, and RM80. I have the Outlaw version and the extra rigidity does help steering, as does the larger CRF150R axle. 2 Share this post Link to post Share on other sites
nots0much Posted October 1, 2019 4 hours ago, Chuck. said: There are CNC top triples available for the Show 37 USD forks used on the CR80/85, CRF150R, and RM80. I have the Outlaw version and the extra rigidity does help steering, as does the larger CRF150R axle. what are you running for the stem and the lower? 1 Share this post Link to post Share on other sites
Chuck. My Rides (3) Posted October 1, 2019 Stock Showa lower and XR250R stem. Honda likes to use different dimensions on parts so they can't be mis assembled. The mini bike stem is steel but is pressed in because the lower triple is aluminum, if it were steel the stem would be welded. The XR250R stem is about 0.015" smaller than the mini bike stem so I used a bearing repair compound good for about 0.020" gaps. I cleaned both surfaces with acetone, applied the compound, assembled the forks with both triples and stem, tightened the clamp bolts, and let them cure for for 24 hours. I've been using that triple and stem for almost 10 years and never had a problem. 3 1 Share this post Link to post Share on other sites
bajatrailrider Posted October 2, 2019 what are you running for the stem and the lower?Lot cheaper I have completet cr85 gold valve bolt on set up CRF 150/230 Share this post Link to post Share on other sites
RedMesa My Ride Posted October 28, 2019 On 10/1/2019 at 2:23 AM, ramz said: But some riders are using XR400R forks now; much easier conversion, better performance, and cheaper. Just for reference, here is the complete 400R process: http://bit.ly/2Rgnujo 1 Share this post Link to post Share on other sites
bajatrailrider Posted October 28, 2019 Just for reference, here is the complete 400R process: http://bit.ly/2RgnujoWhat a expert job you do on write ups. Share this post Link to post Share on other sites
RedMesa My Ride Posted October 28, 2019 (edited) 1 minute ago, bajatrailrider said: 31 minutes ago, RedMesa said: Just for reference, here is the complete 400R process: http://bit.ly/2Rgnujo What a expert job you do on write ups. Thanks, mostly just organize all the great content in these threads Edited October 28, 2019 by RedMesa Share this post Link to post Share on other sites
bajatrailrider Posted October 28, 2019 6 hours ago, RedMesa said: Thanks, mostly just organize all the great content in these threads You do it with such detail even I could do it. Im real bad to try to study reports and do the job but you have a art in details Share this post Link to post Share on other sites
RedMesa My Ride Posted October 29, 2019 19 hours ago, bajatrailrider said: You do it with such detail even I could do it. Im real bad to try to study reports and do the job but you have a art in details Thanks. Main thing is the computer on the workbench. I forget everything as soon as I go in the house. Type in Google Docs and the web version automatically updates. 1 Share this post Link to post Share on other sites
BSAVictor Posted October 31, 2019 (edited) Hmmm, I’d be interested in up to two “custom XR400R forks conversion kits” for my two 2003 California-license-plated CRF230F’s that currently have CR80/85-CRF150R upside-down forks installed (I’m not sure exactly which forks they are; I only do about half of my own work on bikes, and less and less the older I get). The current forks are way better than the stock ones, but I have a Works Performance reservoir shock and a Fox Podium shock on the rears (and I’ve got a new back-up Podium just in case) and would like some more front plushness for the mostly steep/rough/slow-to-moderate-speed single track trail riding that I prefer. My bike currently with the Fox shock has an “Outlaw” type front end. I’d like to convert the other bike’s front end to the XR400R-type and try it before doing the second, “Outlaw” bike’s such conversion, though. ANYONE ELSE INTERESTED IN “CUSTOM XR400R FORKS CONVERSION KITS”?! NOTE: If said front XR400R conversion(s) work(s) out, I’d have one or two CR80/85-CRF150R front set-ups for sale to an interested party(-ies)! Edited October 31, 2019 by BSAVictor 1 Share this post Link to post Share on other sites
