Ori Posted October 1, 2019 (edited) Hey, i have a 2017 yz 125 with full kit of gytr, i wanted to know how much sag do i need? I am 13 yo and weighs 132 lbs. Thanks. Edited October 1, 2019 by Ori Share this post Link to post Share on other sites
mlatour Posted October 1, 2019 (edited) You need 90-100mm of sag no matter your weight (with about 35mm of residual static sag) Unless you ride at pro level speeds, at 132lbs you will likely require one step softer springs, front and back. Stock springs are best suited for a 150-160lbs rider. Edited October 1, 2019 by mlatour Share this post Link to post Share on other sites
Ori Posted October 1, 2019 1 minute ago, mlatour said: You need 90-100 of sag no matter your weight (with about 35mm of residual static sag) Unless you ride at pro level speeds, at 132lbs you will likely require one step softer springs, front and back. Thanks for the reply, i ride 7 years and won israel mx championship 125 - 250 class. 1 Share this post Link to post Share on other sites
mlatour Posted October 1, 2019 (edited) Despite your lighter weight, if your skills allow you to push the bike really hard the stock springs / valving could then be a good starting point. Sending you a message, check you inbox. Edited October 1, 2019 by mlatour Share this post Link to post Share on other sites
