18” Wheel 98 CR250R
What is the Easiest/Affordable way to switch to an 18” Rear Wheel on my 98 CR250R? I’m not finding much and 8 don’t know enough about the axle size or offset to know if ones I’m seeing on Craigslist will fit.
Buying a rim and spokes and re-lacing it yourself to a 18"
that way you are sure that the hub dimensions are correct.
Sprocket & brake rotor alignment / bolt pattern, axle diameter, width etc.
as you are re-using your current hub
By the way you posted in the wrong sub-forum, this is the 4-stroke CRF250R section,
the Honda 2-stroke sub-forum is a bit lower. Perhaps this will get moved by a moderator.
Edited by mlatour
