- Mihajlo - YT -
Beta XTrainer 300 2017 Weird noise VIDEO
A couple of weeks ago I bought a Beta XTrainer 300 2017 with 230+ working hours i ride it 5 working hours for now, the engine goes off as it should have no flaws in Hard Enduro but the other day a weird noise was heard at the machine, I don't know what it was if they were the main crankshaft bearings or what's the problem? whoever can help me would be very grateful to him, by chance i recorded the sound of how that sounds , just turn up the volumen at the maximum so you can hear the noise in the video
https://youtu.be/uB_9kE0zYKA
  • Like 2
Vid don't work. I'll just venture a guess. If your main bearing are going you will hear a off throttle rap, or bumping noise. A rattling is piston slap, a clacking is a valve train noise...
Where can i send you the video? If you can help me
1 minute ago, M E T A L A C I D said:
Just use your mouse to cut and paste it up on here. Or you might try you-tube, and post a link.
I have this link its uploaded on youtube
I should check them first , thanks for the vid
Pull off your alternator cover, then give the rotor an up and down and side to side wiggle, there should be no play or just a tiny bit. If its ok, then it might be the easier top end, piston, rings, valves, timing chain etc... Good luck!
Edited by M E T A L A C I D
  • Helpful 1
Valves. Timing chain? What are you drinking? :smirk:
  • Haha 3
Sat what now?
If it’s the main bearing you’ll likely hear a screeching noise. It’s been well documented.
Edited by Hammy-56
Thanks for the help😀😀
3 hours ago, Hammy-56 said:
Sat what now?
On the vid when i turned off the motorcycle you can hear some screeching noise
Drop bear, you so silly, the film was indeed short, and it sounded like a chain to me. So quit trippin' dawg, you threw in your opinion, and I threw in mine dawg, so chillo my gorilla...😀image.png.642ae9cbf65a503751de578b6e933aab.png
  • Haha 1
11 hours ago, Hammy-56 said:
Sat what now?
Rod bearings make the rapping noise, mains make a screeching, Got it! Perciate the update, now chillo my gorilla...Btw, I had an 86 cr that made a rapping noise, and it was the rod and main bearings that's what the mechanic told me, so I have been told wrong, Preciate that my man. Got it!😉image.png.500c9ecbf1b6fc2852b30fa41186b26b.png
17 minutes ago, M E T A L A C I D said:
This is funny, the bopsie twins were quick to criticize my opinion, and instead of offering a hand to the poor chap, they went after the METAL. Bless yall's hearts.👍image.thumb.png.faee5d63d91520172342edec4748c095.png
Calm down.
We did offer helpful/factual information. And nobody “went after” you.
You were unsurprisingly criticized for mentioning “valve train” on a 2 cycle.
  • Helpful 1
  • Haha 2
19 minutes ago, Hammy-56 said:
Calm down.
Wait a minute, its a 2 stroke? Hell, didn't know that. It's hard to tell what " that" or any modern bike is now-a-days. I'll be damned! No crap!😉 Here is my "opinion" then, from what I heard on the gents short video, I believe he should have let the bike run for at least 40 seconds, then I would have ventured a "guess" like most folks do on TT anyways. I have to physically be there to see and hear what's happening. I think I need to research other bike brands, and their power package make up, before I pull the trigger. Preciate your opinion too. Again, I did not know if the dam thing was a 2 stroke or a four stroke. I am calm, so you can "relax" too.👍
  • Helpful 1
  • Haha 1
  • Confused 1
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
