WildRide
TRX400EX smoking on start up FIX
My 02 TRX400(440)EX started smoking really bad on start-up but would clear up once warm and ran great. Valve stem seals...right? Replaced them with kibble white seals and....NO change at all, still smoked like crazy on start-up. I drained the sump for 20min and just a few ounces came out. Poured the oil back into the oil tank, started it up and NO SMOKE in the last 6 months. My theory: Somehow a little oil had collected in the dry sump and the crank was splashing oil up on the bottom of the piston and cylinder walls.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
