Dirtstache 556
Slavens CDI for 300sx with RK Tek Head
8 minutes ago, 2strokenut said:
Guys, I think you are overthinking this. the 250sx cdi is going to be an "SX" ignition. As Mog stated, guys are running cr250 CDIs in CR500s...
Then why do they bother making two of them ? Looks like version for the newer bikes is for both 250 and 300 but people say it's not as good, leads me to think KTM wanted to save a buck and consolidated into a unit that does both but compromises some performance
Edited by Dirtstache 556
Right.  But per my example, same reed block from 125 to 300, we know KTM likes reusing parts across bikes.
It's not financially sound to make a 300 SX specific CDI unless they see a reason for it.  What the reason is, they don't say.
I'm still on the fence.
They are different part numbers:
'17 - '20 250 SX CDI:  55439031200
'17 - '18 300 SX CDI:  55639031100
Reuse across bikes, and now across 3 brands with the gas gas purchase.
1 hour ago, Dirtstache 556 said:
was going off this site's description that listed it for both:
19 - 20 300 SX kit has same CDI as the 17 - 18 300 SX kit.  55639031100
Edited by redrider144
I think you are asking the wrong question. You should be asking, why does the 250sx ignition work perfectly well in the 300? KTM builds a 250sx, there is no 300sx. The 300 kit KTM sells is just the 300xc cylinder and they provide an ignition that I and others presume, smooths out power since the 300 makes much more power than the 250. Makes sense, how hard is to tweak a curve and sell a different box? It's not.
When I built my first 300sx I had the 300 ignition that came with the kit and went back to the 250sx ignition because it made more power (felt like it) and I liked it more. I really can't comment on all the differences between years but if you can get a 250 box cheap, I'd try it out. It's not going to hurt anything.
  • Helpful 1
Good point might give the 250 box a shot if I find one cheap. I'm not really looking for a huge hit of power I like the liner delivery I have now with the 300 but more power across the board.
I miss not having a 2-stroke. All this banter is making me think I should get another one :LOL:
  • Like 2
  • Haha 2
2017 250 SX CDI is the same price and available within a week, so that's what I went with.
I ended up just canceling my order. Did a harescramble this weekend and at no point was I thinking "Man I could really use more power" Mostly sandy and flowy single track with lot of sand whoops mostly ran in 3rd with no problem needing more bottom end
Just curious, what pipe are you running?
FMF Gnarly and Powercore 2 (the old school skinny one) then RK Tek, lectron HV series,  minor air box mod (just cut the flap off the door)
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
