NEED HELP PLEASE drz125l
my clutch cable broke i changeged it took the pieace off crank case put it all back together now wont engage all the way all i have cable extended all the way as well idk
Did you use an OEM cable? Did you leave the actuation arm attached to the engine or did you remove it. Incorrect installation of the arm can screw it up.
Correct installation of the cable is to first attach it to the engine, route it (using the still in place original) then to the clutch lever on the handle bar.
If you removed the actuation arm at the engine. you must disconnect the cable. The arm, when lightly pressed, should be at 90 degrees to the cable. If not, remove it and reinstall it a spline back to get it to be at 90 degrees. Then attach the cable and then  attach the cable to the lever, then adjust the cable to enable the lever to move abut the thickness of a nickel before resistance is felt.
