nickmell
Rebuilding drz125 shock
I have a drz125 that and fixing up to sell, shock is blown and used ones on eBay are pretty pricey so I'm wanting to rebuild it. I've found seal heads for it and have fluid but I'm not sure how to charge it with nitrogen. I've rebuild a few modern ressovior shocks but non rezzy shocks are new to me, any tips would be great.
You have to drill and tap a Schrader and make it an emulsion shock ,if you search utube you might find a video
Ok I've seen some pics of that done before but wasn't sure if there was another way to do it. That's no problem I can do that.  What psi would I be shooting for?
On 2/14/2020 at 6:35 AM, mog said:
Most shocks run at 145psi
Ok thanks. Do you think these valves will work ok or are there better options?
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
