AEES
Rebound stack kyb, shims order...?
Just got to ask, as I read this valving stack I got, the 4x 20x0.11 is the last shims I add to the inner rod, before I put on and tightening the nut?
Feels a bit wrong order?
And the 1x 12x0.30 is the first shim of all to add to the rod?
Kyb technical touch kit for sxf/WP AER.
That's not listed correctly
The big shims (20s ) are the face shims and to against the face of the piston
Thats what i figured, thanks. Strange that Technical Touch does not get the order right. Or maybe they just figure i should know if im anyway revalving it myself so to say.
  • Like 2
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
