XR600R 87 xr600 backfires but wont start
87 xr600 twin carb, recently rebuilt engine:
new piston +.75, new rings, rebore to suit. New stem seals. Tested head with fuel in the ports (to test valve to head seal on each valve - no leakage. New head gasket Thoroughly cleaned carbs and set them up as per manual. Fresh fuel
I can stand on the kickstart on compression stroke - so hopefully valves etc ok, valve timing marks on either side of camwheel very close to level on the marks against head
Hasn't run since rebuild.
It will pop/bang on demand- ie kick it over and it will backfire/pop/bang not kick, kick, kick, kick then a random pop.
Does anybody recognise whats wrong? PLEEEEAAASE!
thanks in advance people
Did you rebuild the engine or someone else, Have you done any troubleshooting?
Sure sounds like timing if it all looks good check the flywheel woodruff key could have sheared from a back fire
Thanks I will check. Does it sound like 'a long way out' or close? It turns over cleanly so it cant be miles out-i'd smack the piston on the valves if it was too far out wouldn't i(?)
Thanks for your response. I rebuilt it, my 7th Xr and the first totally unsuccessful.. I have removed the kill switch.
I have swapped out the CDI then the carbs then the alternator one at a time with the same results.
Fresh bore and new piston/pin/rings( definitely Xr not Xl piston)
Tested the pickup and it's within spec
Spark is good and I have cut down the lead, changed the plug.
Changed the fuel.
Any suggestions (other than sell the f&+#!Ng thing) welcome please....
Sometimes when they shear they spin slightly and sometimes a quarter turn - either can create a head scratcher...
Just checked the woodruff key/alternator/ crank all ok - as in all inline, mounted correctly, not sheared. Is there anything else that could cause this effect? thanks
Not sure if you addressed this already but now I would look into the valve clearances if too tight well you know...
anythings possible-worth a check. I'd be surprised that there was enough compression to even bang once tho..
With fuel in cylinder and spark - bang eventually if valves too tight most fuel will not get there...
15 minutes ago, cyclewizard said:
I would re-check your cam timing.
I just have. At the same time i stuck a pencil down the bore and it looks like the marks dont correspond to tdc.  T - which i thought was TDC is not- on the T mark it is between the F and the double strike marks
The magnet hasnt spun ( as BPPerformance suggested it might have).
This makes sense- the cam timing is out but the marks are wrong... EH? So it looks like ive followed the marks and thats why the bike wont start!
Posted (edited)
So it appears as tho my marks arent in the correct place, unless tdc is not the absolute top
Edited by Johno1970
mistake
Well looks like you probably have found your problem. Let us know Curiosity kills me.
FIXED.
BPPerformance gets the virtual beer, it was timing.
Thanks to all who contributed and tried to help
BUT
It was a mistake that i didn't think that i would be able to make. So i can add that to the list of normal mistakes then-
The rotor tag will fit on the crank (maybe just the 87) whereever you like. Whereas before I have been used to basically rotating the tag round gently until the wide gap finds its natural position. NOT RELIABLE!!! I proved three times that the tag would fit wherever i chose as long as it was on whole splines- GRRRRRRRRR
I know and i have read several times that it should only fit on one way/ one position- ie look for the very wide spline and match that to the crank - not true in this case.
It fired easily once: 1.sorted correct engine turning direction. 2.Back up a bit from TDC (mindful of note 1) but not as far as F mark. 3. Tag should fit bang on middle of pickup 4. Fire up.
Hope this helps someone else.
Johno
