PAdr650Guy
DR650SE / Yz450f Fork Swap
Posted (edited)
I have a 2013 DR650SE, with heavy springs and intimidators because I ride to the trails and do a lot of off road, I have decided to do the USD forks.
Luckily, I already have a set of 2004 WR450R 48mm forks and Triple Trees.
I plan to keep the front end as close to the DR as possible by using the DR wheel. Since I have not seen anyone convert the original hub to a 20mm axle I figured I would try.
Stem: I purchased the All Ball bearing conversion set for this. Will use a spacer or Press DR stem onto YZ bottom clamp
Wheel: I ordered some 20mm x 35mm x 9mm wheel bearings to replace the 17mm x 35mm x 10mm.
Fairing/mounting: I purchased a set of DRZ light brackets to mount everything. Will customize mounts for Ignition Switch and Dash....
Brake: I also ordered a 270mm Rotor bracket for the YZ forks and a 270mm rotor. DR Caliper mounts to the forks.
My main issues will be  rotor and wheel spacing.
As I work through this I plan to post pictures of the build to assist others.
I would prefer to keep the stock speedometer and thought about swapping the speedometer assembly box with the DRZ since it is 20mm.
I know I could machine a top hat for the DR axle and that will be plan B if I cannot make it work on the YZ 20mm axle. If you have one I would buy it 🤪
Plan C, will be use a YZ front wheel and get a digital speedometer.
Obvious I could change the hub, but that wouldn’t be as fun😉
Any advise would be greatly appreciated!
Edited by PAdr650Guy
Yz450f stem is 30mm and so is the DR stem. However the YZ stem is about 15mm too long so rather than using a spacer I am going to press out the YZ stem and swap it for the DR stem. 🤞
I am interested to see how it turns out.
The DR650 stem fits perfectly in the YZ triple. This eliminates the need for a spacer, and allows you to use original DR650 Bearings
  • Helpful 1
Need to buy, one inch bar rises to clear the forks. Also, eliminated the stock ignition switch, will replace with DRZ.
Slowly making head way. The bracket I bought doesn’t give me enough room for the stock rotor, so I will have to make an adapter.  Ran the speedometer cable and brake cables nicely with the YZ forks.
The pro cycle Dash relocation bracket and light mounts for turn signals are going to work perfectly for these triple clamps.
Users some angle aluminum to mount the speedometer, to the same area as stock. Not sure if I’ll keep, it like this or not. Lastly need to mount the ignition.
very nice! the only negative of such projects is that as soon as youll start off-roading, youll notice how much the rear shock sucks 🙂
Rather than manufacture a brake caliper adapter from scratch I purchased the YZ450F 320mm. Obviously this bracket is too large. I Then purchased a m8x1.25 tap, and 2 m8x30mm stainless bolts as the stock DR650 bolts where much too long.
Posted (edited)
Project Completed. Issues I ran into was mostly just Fabrication of the brake bracket, and mounting the speedometer and dash lights to new triple trees.
On 4/23/2020 at 3:37 AM, turboguzzi said:
hit any trails yet?
Yeah it’s night and day, I am so happy with the turn out.
also I reworked the dashboard, and forgot to post a picture of that. I used a Suzuki Boulevard ignition rather than DRZ. The Boulevard is literally plug and play.
Fyi: the front wheel required a 4mm spacer between the right fork and the speedometer hub assembly.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
