ADVICE PLS!! Oil feed and circulation from bottom end to top end
Hi guys, I’ve got a 2005 kxf250 here and Im concerned about how oil is fed from the bottom end to the top end ... anyway I bought it blown up... I’ve had to buy new bottom end casings, new cylinder head new valves all that lot.. but once it was put back together and oil was put in, I went to re time the bike and noticed there was no oil by the magneto hole, I took the side cover off to inspect whether oil was actually in this side casing where the conrod and big end bearings sit and there’s nothing? But normally oil is fed through the timing chain to the top end isn’t it?
you can clearly see by the sight glass there is the right amount of oil inside there (not to mention I measured the amount of oil I put in anyway) I’m just wondering if there’s another oil top up point I’m struggling to find or is this just how the bike is? Because there is two oil drain hole plugs so it’s just a thought, any advice will be appreciated!!
