Started as a intermittent starting problem and now it’s full time.
No spark and no fuel pump. Relays are new
Clean your negative battery terminal, the ground cable terminals and the ground cable's mounting point on the sub-frame with some sand paper.  I had an intermittent issue where I'd press the starter button and get nothing.  It went away after cleaning up the ground connections.  It might be worth checking/cleaning the corrections at the front of the frame too.  It's been a while since I've done that and I have a bunch of other bikes.  But if I'm remembering correctly I think they all come together at the coil.
Doc
Edited by Doc_d
I had intermittent starting issues as well, and traced it down to corrosion around the white plug that connects the key ignition, as well as the plug in the airbox area. I actually found this out when I was going keyless with the Sicass plug, which plugs into that corroded plug in the airbox. It was the typical blue electrical corrosion, and quite a lot of it. I cleaned it all up, added dielectric grease, and now the bike starts every time.
