Hairline crack magnetic cover and hard water stains
Hi
I need a bit more help
First question:
I took the magneto cover off my engine and I noticed two hairline cracks in the cover.
Is this something I should be worried about?
Should I be looking for a replacement cover?
Second question:
I noticed the static assembly is dull. Should I be polishing these things up?
Third question
With the cover off I noticed the inside assembly had grains of sand and hard water stains. I’m going to clean that up but anything to be worried about?
Thanks for the help
Alex
You can clean up the mag lightly with some scotch brite but don’t spray any chemicals on it. Good thing is this cover is solely to keep it debris just use job weld but don’t get it on the gasket surface!
So I gotta say...in a polite tone....all that corrosion is from moisture, maybe the bike lives in a wet, salty environment, or maybe the cracks in the cover have been leaking water.
Also I see a loose engine mount bolt...that looks to be rather wobbled out??
I wonder if the mag has been rubbed because the crank bearings are bad or at one time it hucked a crank??
  • Like 3
Hi
 No idea regarding  the history of the bike.
My son and I bought it online as a winter project. I also thought that the hard water stains were sea water related but the bike’s registration says it was first bought in Ontario and been here ever since. And we don’t have sea water heat
Good eye regarding the bolt. It’s loose to remind me that I need to add a washer to it.
Should I be polishing up the stator?
thanks
Alex
All of that powder and build up in the case is corrosion which is typical. Just clean it up with some scotch-brite and wire brushes, then coat the surface with some type of corrosion inhibitor like WD-40 Specialist Long-Term Corrosion Inhibitor or LPS3. The stator looks fine and can be coated with the corrosion inhibitor, just don't get any on the crank shaft, the taper needs to be free of any oil/residue. If you choose to JB weld the cover, then stop drill the crack and use JB weld original.
WD40 is not a rust inhibitor ....... It's a moisture displacement product .      Not good for much else ......
Actually it's good for a lot of things. Cleaning plastics and metals and it is a light lube. As you say it's primary use is water displacement but to say it's good for nothing else is just false.
I always use it to clean the stator and leave a light lube to prevent the ignition area from looking like above.
Edited by tribalbc
Use it if you want ,  I just like other products better .  But I guess it's better than nothing ....
https://www.wd40.com/products/corrosion-inhibitor/?specialist=GoogleBrand&gclid=CjwKCAjw_LL2BRAkEiwAv2Y3SW4xbu5AYG3S0LU4OoBmBOgQ6LA2b7K20Rq-WAhAGL8D0g6LxJEDnhoCtT0QAvD_BwE
WD-40 has an extensive product line to cover all your spray lubrication needs👍
On 5/23/2020 at 12:33 AM, acolic said:
What would you recommend?
I like LPS 2 ,   Just a great penetrating and lube for everything ...
