2011 Husaberg FE 390 standard OEM clutch installed
Hi,  I'm looking for some info/help. 2011 Husaberg FE 390 standard OEM clutch install. So I just replaced my clutch plates and springs. Now I'm getting a slight rattling noise from the clutch side of the engine in neutral and it even noisier in gear. Another thing it felt really odd in the shifter kinda like I wasn't getting it in gear and first didn't exists. Did however get it into gear and the clutch did engage but it sounded incorrect so I killed it. Any ideas? Thanks in advance
did you slide the clutch basket out of the main spline shaft?
did you install the shudder spring?
do you still have this rattling noise?
