SlowRZ97
Drz stator install starter issues!!
Hey everybody im at a loss here about whats going on with my bike. I installed a new rickey stator in her but now i cant get the starter to engage/spin. I have a viedo i took and ill post it here. Not really sure whats wrong maybe wireing or i put something in backwards. Any help is welcomed!!
Starter Problem Video (sorry its in vertical)
Posted (edited)
Did it work before?
Is your battery fully charged?
Does the motor spin if you take the stator cover off ie is it binding on the stator cover?
Edited by GuyGraham
11 hours ago, GuyGraham said:
Have you watched the vid closly, as the idler gear is visible but the motor itself isnt turning
yes the idler gear is in there
13 hours ago, GuyGraham said:
Did it work before?
the starter did work before install and i charged the battery up all night and its still making the noise
Take the stator cover off completely and try it
will do! i also tracked the sound to the starter relay and im going to test that as well.
If the relay is making that noise then chances are its dead and needs replacing
Could it be just a bad conscience that the relay goes out right after I swap the stator? It was working decently before. And i measured ohms between the wires and im getting 4.5 ohms so that's in spec but im waiting for my battery to charge to test continuity.
The starter relay under the seat is known to fail from time to time.It is either good or bad.Nothing really intermittent about it.Even if it tests bad it didn't have anything to do with your stator and starter clutch repair.
Edited by bumtarder
what if its testing good? it passed the ohm test and i cant jump the terminals with a screwdriver it still just clicks and makes that wrrrrr sound. Im starting to think the relay is ok but im still new to this
16 hours ago, bumtarder said:
Are you testing with a known good fully charged battery showing at least 12.7v?
the first few tests i was but then the battery would drain
Ok well,you can't do anything unless the battery is fully charged or you jumper from a booster pack or car battery for doing the testing.If you jumper from a car make sure the car is not running or the bike will see full output current from the cars' alternator.
ill try that thanks! I also tested the contunity and its showing zero from the relay. That means bad relay right?
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
