How does Throttle Assembly Work?
Hi
quick question on how the throttle assembly works on a 1990 RM125.
Is there supposed to be a return spring in the assembly?
Meaning if you increase the throttle by rotating the grip clockwise and then release the throttle grip, should a spring turn the mechanism counter clockwise reducing the throttle?
Or once you move the throttle to a position it should stay set until you move it.
thanks for the info.
Alex
There is a throttle return spring inside the carburetor, item #20 here:
https://www.partspitstop.com/oemparts/a/suz/50d3849bf8700229982f1609/carburetor
Apart from a weak or mis-installed spring, if the throttle does not promptly return when you release the grip,
it can be be caused by a frayed/worn/dry/improperly routed throttle cable or, a damaged throttle tube assy.
Considering this is the first time I have assembled a carb I will go with I probably screwed up.
I know it’s difficult but does this look right?
