3x3 mod issue
I have a drz400sm with FCR 39 Mx carb, installed 48 pilot/ 160 main, full yosh exhaust & 3x3 mod. Runs better with clean towel in 3x3 hole. Can I tape hole up?
Rather sounds like you need to enrich the jetting.
Tapping it up would be a 'band-aid' fix and likely choke up the full potential of your Yosh exhaust.
Live in Midwest, throttle response, decel popping, re do jetting?
Enrich jetting? Total throttle response, decel popping.
This will likely get moved to the appropriate sub-forum where you'll get more experienced members with these mods.
but throttle response is likely more accelerator pump related and,
popping on decel can be either jetting, a characteristic of that pipe or, a bad header-to-head seal which allows for an air leak.
Edited by mlatour
Depending on what state ya live in, would like to know what's a good jetting for Milwaukee WI. Back to drawing board.
Definitely a jetting issue.  The easiest way to deal with that is to install a JD Jet kit.  They give you everything you need and the instructions are very easy to follow.  Or just tape over the 3x3 hole and live with a lesser performing bike.
- you call.
