Joseph Garcia
2002 Yamaha blaster Help !!!
Hey guys just bought a 2002 Yamaha blaster but the problem is when I first rode it after buying it the oil light turned on then turned off and I was riding it at night so when I would break the lights would start to go dim it eventually ended up turning off and leaving me so I was luckily able to get it back on  so I drove it back home and with my trx250r I usually mix oil in the gas and for some reason i don’t know why I did it but I put some oil in the gas tank and shook it but I ran it for about 10 min and the light Came on again but this time stayed so I took it back home and parked it for the night and when I did research I realized I wasn’t supposed to mix oil in the gas because it does it automatically because something about being oil injected so it automatically mixed but I didn’t run it for long how do I fix this error and flush the gas system or carb or do I just Empty the gas tank and run fresh gas to burn what I just did ?? Help
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
