2013 crf 450 running issues
Hey just wondering if anyone else has had this issue with there bike and could point me in the right direction
anyway starts perfect with or without the fast idle pulled out,
but once it warms up completely (roughly 3 minutes of idle) it just shuts its self down you can keep it going with the throttle or by pulling the fast idle out and doesn’t throw and DTC’s or mil lights
you can ride it and it’s fine not loss of power or anything along those lines but it try’s to shut down when you get off the throttle eg: going into a corner
I’ve already checked
good spark- hot and cold coil
fuel pump and fuel filter good and clean.
Air filter clean- issue still there with it in or out
fuel cap and breather not blocked
valve clearances in spec
compression is in spec
spark plug has been replaced
injector clean and working perfect
maf sensor cleaned
19 hours ago, Brendan Sharp said:
Sorry should of said that I’ve done that already and doesn’t help it
you need to pull the injector body and clean it. I've seen that idle air passage clogged clear shut.
DONT TAKE THE TPS OFF IT.
You could check the TPS values and the resistance through the range. If it's gone bad down at the bottom of the throttle range, it should throw a code on the kill button, if the voltage signal was low.
