First Peek: 2021 KTM XC-W, XCF-W and EXC-F
2021 KTM 500 EXC-F Highlights
  • NEW graphics with updated color scheme for a READY TO RACE appearance.
  • UPDATED WP XPLOR forks now feature an external preload adjuster as standard, making spring preload adjustments for terrain and rider preference quick and easy.
  • WP XPLOR rear shock with PDS (Progressive Damping System) technology features a second damping piston in combination with a closed cup towards the end of the stroke, supported by a progressive shock spring, to produce unmatched dual-sport performance.
  • NEW shift locker provides increased durability.
  • High-tech, lightweight chrome-moly steel frame with carefully calculated flex parameters provides a great blend of comfort, stability and precision.
  • Single-piece cast aluminum swingarm is manufactured using a gravity die-cast production process, offering exceptional strength at the lowest possible weight.
  • Light engine cases with a centralized shaft configuration move the crankshaft closer to the bike’s center of gravity for light handling and quick responsiveness.
  • Reinforced clutch cover for improved resistance against impacts in rocky terrain.
  • 6-speed wide-ratio transmission is perfectly suited for road and offroad duty.
  • Bodywork features a slim design for excellent comfort and freedom of movement, putting the rider in complete control.
  • Airbox and air boot designed to provide maximum protection of the air filter against soiling and better airflow for increased performance. Air filter can be accessed without tools for quick servicing.
  • Hydraulic Brembo clutch system offers highly controllable modulation of the clutch and light operation, minimizing fatigue on demanding rides.
  • High-tech Brembo brakes have always been standard equipment on KTM offroad machines and are combined with lightweight Wave discs to offer incredible braking power and feel.
  • Super lightweight Galfer Wave rotors, CNC machined hubs, high-end Giant rims and Continental TKC 80 tires provide excellent performance while reducing unsprung weight.
  • Offroad specific features such as handguards, a side stand and oversized tank ensure the 2021 KTM EXC-F machines are READY TO RACE.
2021 KTM 350 EXC-F Highlights
  • Airbox and air boot designed to provide maximum protection of the air filter against soiling and better airflow for increased performance. The air filter can be accessed without tools for quick servicing.
2021 KTM 500 XCF-W Highlights
  • Offroad-only model that sheds the signals and mirrors and features more aggressive mapping and a less restrictive power pack than the KTM 500 EXC-F, meaning more power to put to the ground through the full-knobby tires and a lighter overall weight.
  • WP XPLOR rear shock with PDS (Progressive Damping System) technology features a second damping piston in combination with a closed cup towards the end of the stroke, supported by a progressive shock spring, to produce unmatched offroad performance.
  • 6-speed wide-ratio transmission is perfectly suited for offroad duty.
  • Handlebar map switch selects between two maps (standard and more aggressive) and activates traction and launch control for enhanced grip in challenging terrain.
  • Super lightweight Galfer Wave rotors, CNC machined hubs, high-end Giant rims and Dunlop AT81 tires provide excellent performance while reducing unsprung weight.
  • Offroad specific features such as handguards, a side stand, skid plate and oversized tank ensure the 2021 KTM XCF-W machines are READY TO RACE.
2021 KTM 350 XCF-W Highlights
  • Offroad-only model that sheds the signals and mirrors and features more aggressive mapping and a less restrictive power pack than the KTM 350 EXC-F, meaning more power to put to the ground through the full-knobby tires and a lighter overall weight.
  • 6-speed wide ratio transmission is perfectly suited for offroad duty.
  • Air box and air boot designed to provide maximum protection of the air filter against soiling and better airflow for increased performance. Air filter can be accessed without tools for quick servicing.
  • Offroad specific features such as hand guards, a side stand, skid plate and oversized tank ensure the 2021 KTM XCF-W machines are READY TO RACE.
2021 KTM 300 XC-W TPI Highlights
  • 293.2 cc 2-stroke engine fitted with a patented TPI fuel injection system for perfect fueling at any altitude, no premixing and reduced fuel consumption while still living up to the standard of a KTM 2-stroke.
  • Cylinder with two injectors placed in the rear transfer ports for excellent downstream atomization of fuel.
  • EMS featuring an ECU controlling ignition timing and fuel spray based on information from sensors reading intake air pressure, throttle position, water temperature and ambient air pressure from an additional sensor for efficient altitude compensation.
  • Optional map select switch allows the rider to select an alternate map, providing a sportier power delivery, while the standard map is set for smoother and more tractable offroad characteristics.
  • Electronic oil pump feeds oil from the 700 cc oil tank to the intake to ensure a perfect fuel-oil mix under any condition while reducing smoking by 50% and providing up to 5 tanks of fuel.
  • Exhaust system provides improved performance with reduced weight and a more durable construction thanks to the innovative corrugated surface on the expansion chamber.
  • Offroad specific features such as handguards, a side stand and oversized tank ensure the 2021 KTM XC-W TPI machines are READY TO RACE.
2021 KTM 250 XC-W TPI Highlights
  • 249 cc 2-stroke engine fitted with a patented TPI fuel injection system for perfect fueling at any altitude, no premixing and reduced fuel consumption while still living up to the standard of a KTM 2-stroke.
2021 KTM 150 XC-W TPI Highlights
  • 143.99 cc 2-stroke engine fitted with a patented TPI fuel injection system for perfect fueling at any altitude, no premixing and reduced fuel consumption while still living up to the standard of a KTM 2-stroke.
  • NEW cast piston replaces the forged piston for improved durability while keeping weight to a minimum.
Posted (edited)
So nothing really new except for the preload adjuster and map switches (which the white bikes come with already)?
Edited by jrodicus100
  • Like 2
1 hour ago, Doc_d said:
Sounds like pretty minor changes for 2021 in the XC-W, XCF-W and EXC-F lines.  I wonder if the XC line will get a larger overhaul this year.
Doc
I was wondering the same. When do they usually release info for the XC line?
No, it says "bold, new graphics", so pretty much "all new"! 🤪
  • Like 4
  • Helpful 1
  • Haha 2
Three fitty don't have no revised/updated CCT. If they's not updatin' it; it must be too good to fail. :ride:
The splash of gray harkens back to the 98-00 models. They're running out of BNG just like Yamaha. :D
150 changes the forged piston for a new cast one for improved reliability.........what?
  • Helpful 1
My 2018 is treating me so good, I'm going to keep her another year. Have been on a 3 year cycle forever, but this one deserves a fourth.
Won't hurt to let KTM perfect TPI a little more....maybe grab a leftover 2021 next spring if their giving deals.
Lucky there is a 2021 with any changes. Thought Rona would screw it up.
Looks like nothing changed with the TPI’s. Same as 2020?
The items I mentioned above look like they apply to the 2t bikes as well.
Posted (edited)
No, the map switch is optional just like in 2020.
Quote
Doc
Edited by Doc_d
Same here, my 2018 350 has treated me really well something about those even year bikes.  Been eyeing a TPI 300 for awhile now, might wait one more year as well.
The Marketing Department outdid themselves for 2021. Not much substance other than buzzwords beyond this:
The 2021 KTM Enduro portfolio is set apart by its fresh and truly READY TO RACE graphic scheme and updated color palette,
  • Haha 3
The "optional" map switch have been optional on Orange bikes for years. Blue ones come with the switch. The wiring harness of my 2017 is ready to plug the switch in.
Yeah I got it, just missed the “optional” part.
  • Like 2
  • Confused 1
Posted (edited)
^ This response was sarcasm in regards to a lot of long winded marketing hype for not much more than Bold New Graphics.
Edited by 76xtdrvr
I never explain my sarcastic humor. Sorry, policy. 😉
  • Like 2
  • Haha 1
