2018 coolster 125 214FC clutch isn’t working please help!
So I bought a 2018 coolster 125 dirt bike and the old clutch kinda just quit working mid ride to the point of where it doesn’t take the motor out of gear so , when you start it and pull in the clutch lever and put bike in gear it just stalls , I’ve bought rn and replaced the entire clutch and still have the same problem any tips ?
make sure your levers are properly adjusted, then what i do with my ssr 160 tr is wrap something around my the clutch lever and i leave it for a minute or so to get the clutch plates loosened up, i have heavy duty clutch springs so i have issues every time i leave the bike for a week or so then go to ride the clutch just doesnt want to let go of itself, with your new clutch i would assume it is very grippy, did you soak your clutch disks in oil before install? if not you might need to
Hey! We meet again!
4 minutes ago, Penncraft 70 said:
Hey! We meet again!
i always try to lurk around to help whenever someone needs help
Haha!
On 6/27/2020 at 5:46 PM, Skylar Willsie said:
Anyone have a diagram for that bike to make it a little easier ?
Hey dude! Sorry for the late reply but here’s a Pitbikes clutch diagram... as you can see there is many clutch plates, but in between each clutch disc is a metal disc (not a flywheel). That all the discs rub against when you realese the clutch. The metal discs are fixed to the clutch basket below the clutch set. Everything fits together tightly. When you pull the clutch lever in, your moving the clutch discs away from the metal disc. Hope that helps!image.jpeg.0030b30d6addd0ba2b96a17670bcc67d.jpeg
I have had problems with a sticky clutch in my ssr 160 tr, i removed the clutch side cover of the motor( drain oil first or you will have a horrible mess) and cleaned and reoiled my clutch arm( the little lever that decompresses the clutch. Another option is to wrap a ziptie or tape around the clutch lever for a few minutes( this helps the clutch plates loosen up after a few days-months of sitting). Then remove the tape and it that doesn't help....well there is one last eay to break the clutch loose but it is a last resort is rev the bike up in neutral and while the is high in the revs and pop it into first( dont do this unless you know your cutch is properly adjust) this can cause wear internally (gearbox mainly)if your doing this so again last resort!
Well I’ve let it soak in oil and I’ve zip tied my lever , nothing worked , I’m still having clutch problems I took motor off and took it apart and completely went through and cleaned and reassembled , fired up first kick no choke but still no clutch
If you’ve tried your best trying to fix it your better off taking it to a mechanic, small engine repair, etc.
So what did you end up doing to get it fixed Skylar Willsie ? I'm having the same problem with a Coolster 125cc pit bike.
On 7/6/2020 at 11:46 AM, Skylar Willsie said:
Got her fixed thanks boys for the help
Got her fixed boys
What did you do to fix it ? I'm having the same problem with ours.....
Try to ziptie your clutch lever and leave it for a day or two and try and pop start it and put it on a bucket and let it idle if you can that’s what made mine start working just need to be oiled good
