Transmission Oil?
I just got a 2014 Kx250f and I’m coming off of Honda’s which you have to change the trans oil and engine oil separately. Does the Kx250f require that as well or do you only need to fill the one side? Thanks!
I have an 11. Great bikes. Your manual will literally tell you everything you need to know. Do yourself a favor and get one.
Just one place for oil. 750 ml. 800 ml if you change the oil filter. 1 liter if cases are empty (like after a rebuild). If you install the oil filter backwards you can fry the engine. That's why you need the manual.
Yup just one place to fill. We always run more oil. A full quart or even 1000ML
