Choosing a decent chain
Hello,
  I've been using DID 520 DZ2 Chain Gold #520DZ2 and Renthal sprockets for a few years but I wanted to adventure outside my safety zone and experience a different type/brand of chain that might be slightly better then the DID that I'm using  open to any suggestion or brands you use or should I just stay with the DID chain?
I would like to stay around $80 for a chain and has to be gold in color as I never used o or x ring either but if the price is right I'll try it.
My beast is a 2002 YZ426F sprockets I'm using right now are 14/49 (Renthal -Aluminum) soon changing them soon to 14/52 (TAG Metals - Aluminum) as I mainly enjoy trail riding.
Brands I'm looking at:
Unibear chain
EK chain
D.I.D. chain
Fire Power chain
Primary Drive chain
SunStar chain
ProTaper chain
Volar chain
Renthal chain
You'll get as many opinions as replies. I usually look at the rated tensile strength as a guideline, but for the $ have been running Primary Drive chains on all my bikes without issue.
  • Like 6
The fact that you get away with aluminum sprockets on a 426 tells me that most any chain will be fine.
Run a steel tooth rear and a sealed chain, it will last you 10 years.
  • Like 5
  • Helpful 2
I only have a 300xcw but I run primary drive also without an issue. Plus the sprocket and chain kit are cheap enough to replace regularly if needed.
Your best bet IMO is to run a Supersprox rear sprocket (lightweight aluminum center with steel teeth), or other similar sprocket, and a gold Primary Drive X-Ring chain.  It will outlast any aluminum sprocket/non o-ring combo by many times over.
  • Like 2
DID VT2 (now called the ERVT) X-ring enduro narrow sealed chain on steel sprockets,
even basic steel Sunstar sprockets makes for a very long lasting setup.
 What would be the recommendations chain length to fit my sprockets: 14/52 - 520.
Thanks for your feedback..
17 hours ago, slbwing said:
Hello,
Unibear chain
EK chain
D.I.D. chain
Fire Power chain
Primary Drive chain
SunStar chain
ProTaper chain
Volar chain
Renthal chain
What are the stock sprocket sizes?  Edit: I've found 14/49-114 links as the stock setup for a '02 426F.
Anytime you change the sizing, it's always a guess what chain link count fits ahead of time.
(calculators get you close but no guarantee they are accurate in all applications)
Better to buy a length of 120 links and cut down to size after proper measuring,
making sure you still have room for adjustment later on.
Edited by mlatour
They normally come in various lengths
Your OEM is 520 14/49 114 links so I would count exactly how many you have then if needed buy say a 120 link chain and cut out links as needed BUT you do not want it too short.
I'll leave cutting a chain and adjusting correctly to someone else
Ironically looks like we are on the same page at almost exactly the same time🙂
RK X-ring with Renthal C/S sprocket and Primary Drive steel rear. I have over 8 years on this set with over 1000+ hours on them. I admit my bike isn't as much of a beast as the 426 but should easily see half the life I've gotten out this setup. I will not run an aluminum sprocket on an off road bike unless it's a hybrid like the Supersprox.
Edited by SS109
This
I've also found sunstar aluminum sprockets to last the longest as well.
Take this for what you will - I have a Primary Drive Gold MX chain (non o-ring) with 10 hours on it so far and it’s been fine. I can’t speak for longevity yet but it came loaded with grease from the factory and has a nice fit and finish. Albeit I can’t really say the chain is gonna get that abused, it’s on a 125 haha!
I second this....
this basically what I have been running since 2008
For ur budget, SRT o-ring chain. is an excellent choice.  Better quality than PDrive but abt same dollar.
JT steel sprockets can be found dirt cheap at times.  Not the lightest or prettiest, but last forever as all steel do.
