CR125R Throttle setup
So I have a 98 cr 125 and I ordered a new throttle casing and throttle cable the cable is the right size but it won’t screw into my throttle casing so I have the wrong casing it’s too small for the cable so how do I know what size casing I should get? I’m sorta a newb lol so any info helps
Everything but the cables is available OEM. I've used Motion Pro cables for years with good luck. Matched up to the stock housings perfectly.
Look under the Handle Lever fiche for your bike.
Motion Pro makes replica housings w/throttle cable too. No idea if the make them for your bike.
https://www.partzilla.com/catalog/honda/motorcycle/1998/cr125r-a
Edited by HRC27
Per Motion Pro's site, they're sold separately. You have to use their 01-0713 cable with their Vortex throttle housing for example.
If you have one of their housings, buy the matching cable.
If you bought a cheap housing off ebay, that's your issue. At least get a Motion Pro and it's matching cable.
https://www.motionpro.com/product/01-0713
https://www.motionpro.com/product/01-0054
Edited by HRC27
