08 Wr250r -- remove 'push' throttle cable??
I'm planning on replacing the throttle cable on my 2008 Wr250r. (it's a little stiff and way old; and I ride solo a lot). I'm considering leaving out the 'push' cable and just replacing the 'pull' cable. From what I know, it's a requirement on road legal bikes but doesn't really seem necessary in my eyes. What are your opinions? They're sold as a set, so I'm not being cheap (which I am) but just trying to simplify the bike....and maybe make the throttle pull a little easier. Thanks in advance, YO
I'm not familiar with the WR's but I have a 03 DRZ and a 05 CRF and IMO the throttles are super easy to open and work perfectly.
If it was me I would just replace both cables, make sure they are routed correctly and the throttle tube is clean/not damaged or binding.
Otherwise can you better describe why the throttle is not easy?
The throttle is not terrible on the WR but I broke my wrist as a kid and I'm developing tennis elbow as an adult; so I'm trying to make things as easy as possible. I heard the throttle tube from a 06-15 R6 streetbike has a quicker pull and is a direct fit. Can anyone chime in on this one? Is the motion-pro R6 tube the same as oem?
Theres throttletubes with bearings and such for a even smoother pull. I believe the G2 throttle tube has that as an option.
I've heard talk about the R6 tube, but for you, a shorter pull doent mean it takes less effort.
You can also try lubing the cables. I use something like this Motion Pro one and Maxima MPPL since I've found its not stick and works good but you get various options on lubing cables.
I have not tried the G2's but something I might look into and if your not using full wrap guards as posted you can get aluminum throttle tubes with bearings and used on for quite awhile and liked it a lot but ended up putting on full wrap guards and had to cut the end off.
I just say this in this months Dirt Bike and has bearings on both ends and MIGHT be an option as well.
https://www.zrthrottle.com/product/zero-resistance-throttle-006/
Good Luck
Push-pull throttles are a measure to deal with slide stick caused by the strong vacuum signal. Clean and lube or replace if necessary, don't remove the push.
Removed the push cable on my xr350. It’s there so you can force the carb closed if it gets stuck open but like 80% of the time it doesn’t work anyways. Throttle is much more smoother. I didn’t have an issue with getting my bike safetied after removing it either.
