Well ya know what the farmer said when his cow died
It never did that before ....
  • Haha 3
40 minutes ago, Adrien Bechard said:
80 honda xl185. Doesn't seem to go in gear but I took off the cover and it changes gears just fine. Clutch looks good too.
Just so you know, I didn't reply, because I don't have a clue :D. I didn't want you to think I just left you hanging 😉
Crypto sounds pretty confident. I'd imagine there's a reason why :D. I reckon he might be speaking from experience.
Good luck.
Edited by Drop-Bear
37 minutes ago, Adrien Bechard said:
I had the cover off and it shifts through the gears just fine.
How do you shift through all the gears just fine without the rear wheel turning?
If you can spin the rear wheel on a stand and shift through all the gears "just fine,"  then you should be looking at the primary gear, unless the clutch isn't turning with the wheel.
Edited by crypto666
If you can spin the rear wheel on a stand and shift through all the gears "just fine,"  then you should be looking at the primary gear.
Take photos of linkeage inside cover
Sorry guys....I just got back into bikes after 20 years....I'm a lil rusty. I got the day off tomorrow.
I'll rip it apart again and take some pics.
Thx for the help.
Edited by Adrien Bechard
I'm not going over to his house.  His dog is mean.
  • Haha 1
Ok...so if push down on the kickstarter it turns everything...but if I rotate the back wheel only the clutch basket moves when in gear.   Help20200630_112528.jpg.27d8cd062e199817e056b307c1daaea3.jpg
In that 2nd pic those clutch plates look discolored from heat. Clutch plates along with clutch springs may be worn, causing the clutch to slip. I don't see much oil residue around that open case either. It did have oil in it, right?
It also looks like the clutch plate tangs have worn deep grooves into the outer clutch case. The clutch won't engage or disengage properly.
On 6/29/2020 at 2:20 PM, Adrien Bechard said:
Was riding along fine ....then no more. Bike runs....seems to shift through gears....clutch seems to engage/disengage....what's wrong????
Clean the carb, might of got a bit of debri in the carburetor jets
