2005 ktm 450 exc
Just cleaned carb and new gaskets, got bike finally running. Only has 30 hours on it. From idle when i gas it in neutral it bogs out a little and still runs just cant get a clean rev out of engine every time. What could that be and how do i fix it?
Thank you
Pete
Thank you
Pete
Did you do the mid body gaskets as well as new needle and needle seat when you say gaskets? Other than that check accelerator pump and squirt time. Lots of videos and info online. I did all of these to finally get my 05 525 running well.
Just now, Pete Jakiel said:
Thanks so much will look into these things. If i put choke  a 1/3 on and rev it, it doesn't bog.
You are probably running lean then. Could be due to clogged up carb mid body.
