Jwhisler Posted July 5, 2020 Hello, I have a ttr 125 LE and it is leaking oil at a very slow rate. Probably a dollar coin sized glob every 2-3 days. I don't know where is it coming from but here are some pics. I hope some of you could help me figure out where it is coming from. in the photos there is oil build up on that ridge of the engine Share this post Link to post Share on other sites
YZEtc Posted July 5, 2020 Check the oil seal where the shift shaft pokes out of the engine. Share this post Link to post Share on other sites
trailmeisterjoe Posted July 6, 2020 Yep......looks like shifter shaft seal/bushing. Joe Share this post Link to post Share on other sites
Jwhisler Posted July 6, 2020 Thanks, I was thinking that too, does anyone know how I can replace that? I saw a video where a guy used a drill and then put a screw in it but I was wondering if there would be a better way? Share this post Link to post Share on other sites
bweighmaster Posted July 6, 2020 Just remove shifter linkage , I use an old ice pick to poke a hole and pry it out .. grease well , insert with finger pressure , then tap in with deep socket and small hammer just flush with case ... Share this post Link to post Share on other sites
