Are Pitster Pro pit bikes any good
Pitster pit bikes are good bikes, if the bike has conventoonal forks with no adjustment dials then i woud looks for one with upside down forks with adjustable settings, only way to for the conventional forks to work good is to put in some heavy duty oil like 15-20 weight. When you get these pit bikes you need to spend some time jetting the carb as well, otherwise depending on your elevation it could be running lean or rich, put in some decent oil before you try to start the bike and make sure it is motorcycle oil. Pitster pro and ssr pit bikes are really similar, good bike but need a little elbow grease to be 100% and last long
