Mr. Horsepower Posted July 7, 2020 I recently acquired a 1996 xr600r that was dropped in my lap as a non runner basket case. I dug through the tool pack and found reading glasses and maps, levers were tilted high and rear tire was brand new and dated 2004. gastankwas full of rotten gas, i cleaned the carb, got it running, took carb back apart and lowered needle to get rid of stumble, I am in higher elevation, new oil, filter, new air filter, all new fuellines and overflow lines, new master cylinder rebuild, and appears to be a very low hour bike. Now, i amin CO and i can title the thing easily enough but i need a tail light that has more illumination that the candle in the back. My xl 600 has a more square tail/brake/license plate affiliation. what do you guys use for a somewhat direct fit without drilling and modifying brighter rear light? I looked and searched old posts, found some products but they appeared to be "universal" drill to fit I persume. Is there a dual fillament apparatus that is able to utilize the original mounting locations and a harness change to a 3 wire from a 2? Share this post Link to post Share on other sites
EarthCruzn Posted July 7, 2020 Basically there are three models readably available,.............. that look like what they should OEM Honda , ..... no brake light just a tail light Universal design made by a few....... tail and brake light The WPS (Western Power Sports)....... tail and brake light,,,,,,, some older NOS WPS lights have a white lens for the tag........ File TT photo of WPS Share this post Link to post Share on other sites
EarthCruzn Posted July 7, 2020 I have the WPS, it fits perfect in the stock molded fender. The bulb is the trick for brightness..... I found the Wagner BPB1007 fits the WPS and is bright and very bright when brake light is on.............good thing It is also a very durable bulb and handles vibration well................... the XR kills cheap bulbs by the vibration before they actually burn out. Just FYI.............. I am still on the same bulb 3000 miles later................ many a rough trails have been crossed in that time. Share this post Link to post Share on other sites
EarthCruzn Posted July 7, 2020 Depending on how your State inspection reg's are, you may need a "lighting kit" it has switches for high / low beam, turn signal switch (opt) horn and brake light switch,................. depending on brightness level required you may need a stator upgrade ................... many companies make dual sport lighting kits for most bikes today. The kits are a complete and easier option sometimes...................... or just buy the parts you need and make your own. Share this post Link to post Share on other sites
