2007 Yamaha TTR50e won't start
Hello,
I have a 2007 Yamaha TTR50e that I cannot get started. It was running great, he came in for a quick rest and it would not start when he jumped back on it 10 mins later. I have cleaned the carb, it seems to have a strong spark and strong compression. It sounds like it wants to start but just won't. What else could be wrong, please help!
Thanks!
Glenn
27 minutes ago, GDickey12 said:
Hello,
Thanks!
Glenn
If it has spark and compression,  that leaves fuel and air as culprit.
I would take pilot jet out and look through it for daylight.
Those 50 cc machines have extremely small pilot jet holes that easily clog and cause all kinds of grief.
I think it I have ruled out a fuel issue. Fuel is good, carb is clean and the bike is getting gas. It also won't start with starter fluid. I am going to get a compression tester this weekend and check that out.
Thanks!
Probably flooded .   Remove plug and let it air out ,   blow it out with air hose ,  clean or replace plug ..
2 hours ago, Yukon Daniels said:
I have a 07 Ttr-125 and I want a FMF Exhaust. Will I have to tune my bike or can I just put it on and go? If I have to tune what would it be
If you just want noise , remove muffler plug .    Not much to gain with a fancy exaust ... just put it on ...
