swapnifty Posted July 9, 2020 (edited) Hi guys I know 2 strokes are known for having loud bottom end noises but I just want to make sure this is normal , thanks! https://youtu.be/9R7DsXdwDMU Edited July 9, 2020 by swapnifty Share this post Link to post Share on other sites
BOAB Posted July 9, 2020 Since when are 2Ts known for having loud bottom end noises. Didn't listen to/watch the video, but just asking. Share this post Link to post Share on other sites
Into the sunset Posted July 9, 2020 I can hear a rattle during idle that I don’t have on my 2007. 1 Share this post Link to post Share on other sites
Smoking 2's Posted July 9, 2020 2 hours ago, swapnifty said: Hi guys I know 2 strokes are known for having loud bottom end noises but I just want to make sure this is normal , thanks! https://youtu.be/9R7DsXdwDMU I hear nothing concerning 1 Share this post Link to post Share on other sites
swapnifty Posted July 9, 2020 25 minutes ago, Smoking 2's said: I hear nothing concerning This is what I wanted to hear, I hope you’re right, I can’t afford a new bottom end 🙃 1 Share this post Link to post Share on other sites
Piney Woods Posted July 9, 2020 You will get more info in the Honda 2stk threads. 1 Share this post Link to post Share on other sites
KcDavis My Ride Posted July 10, 2020 What bottom end noises are you referring to? 1 Share this post Link to post Share on other sites
Brian Lassig Posted July 10, 2020 Also, I feel like the phones make the bikes sound different than they do in real life. If that makes sense. 1 Share this post Link to post Share on other sites
swapnifty Posted July 10, 2020 7 hours ago, KcDavis said: What bottom end noises are you referring to? I wasn’t really referring to anything specifically, just wanted to get some other peoples opinions, I just picked this bike up just trying to figure out if it’s strong or not Share this post Link to post Share on other sites
M E T A L A C I D My Ride Posted July 11, 2020 I have loud bottom end noises after a couple of bean burritos. But I love them! LOL! They all sound rattly and noisy. I have 2 that sound just the same. Hell, go listen to a worn out 80's XR, you would swear the would gernade sending shrapnel all over the place. You are going to be ok...Oh crap, I made my self hungary again. Ill never keep my diet going!! 2 Share this post Link to post Share on other sites
Highflier Posted July 12, 2020 It sounds fine to me. Share this post Link to post Share on other sites
Ryan Hobbs Posted July 22, 2020 I have a 96 cr250, an a freshly built 01 they both sound that way , On that same note i have found loose motor mount bolts,nuts before that will make it sound like a bad rod so i would check that stuff every once an a while head stays can loosen also , no need to Torque the stuff over an over just check that its got resistance an not loose when u try to turn any of it, If u do find one clean it an put blue lock tight on it an torque it to spec , 1 Share this post Link to post Share on other sites
Ryan Hobbs Posted July 22, 2020 Also some one put a pdf, manual on here for that bike a few years ago so if u dong have a manual may find it in the cr 250 category 👍 1 Share this post Link to post Share on other sites
jeddclampette Posted July 23, 2020 i agree w/ everyone ..... that noise is common. Every CR250 I've ever come across, including my '05 cr250, exhibited that rattle sound surrounding the lower case. mine had that noise from day one, it's now well over 1200 run hrs on it, and the bottom end is still factory original, still as tight as day one, still has that signature noise. Don't lose any sleep on this. 1 Share this post Link to post Share on other sites
Piney Woods Posted July 23, 2020 36 minutes ago, jeddclampette said: i agree w/ everyone ..... that noise is common. Every CR250 I've ever come across, including my '05 cr250, exhibited that rattle sound surrounding the lower case. mine had that noise from day one, it's now well over 1200 run hrs on it, and the bottom end is still factory original, still as tight as day one, still has that signature noise. Don't lose any sleep on this. This! After 18 years I finally had to replace the crank in my 01, the sound never changed. What brand premix oil(s) do you use Jedd? 1 Share this post Link to post Share on other sites
