Flash1034 Posted July 9, 2020 Does anybody make a complete kit, with instructions, to convert the stock plastic Honda rear brake switch to a metal hydraulic unit? Thanks Share this post Link to post Share on other sites
xpantz Posted July 9, 2020 https://www.ebay.com/itm/Hydraulic-Brake-Light-Switch-Conversion-Kit-Honda-CRF450L-2019-2020-/373087997941 1 Share this post Link to post Share on other sites
R.L. Sheldrake Posted July 11, 2020 I bought a switch from JCR Speed Shop https://www.jcrspeedshop.com/products/crf450l-rear-brake-pressure-switch I also purchased a Goodridge pressure switch (M10x1.25), the 90 degree boot, and the connector from Frank at Cycle Terminal and fabricated a backup. Share this post Link to post Share on other sites
Mike Barger Posted July 11, 2020 When replacing the brake switch, do you have to bleed the rear brake? Share this post Link to post Share on other sites
Apaden1 Posted July 11, 2020 On 7/9/2020 at 4:36 PM, Flash1034 said: Does anybody make a complete kit, with instructions, to convert the stock plastic Honda rear brake switch to a metal hydraulic unit? Thanks https://ap3racing.com/shop/ols/products/hydraulic-brake-switch-conversion-kit plug n play. Just a bit of bleeding! Share this post Link to post Share on other sites
Apaden1 Posted July 11, 2020 16 minutes ago, Mike Barger said: When replacing the brake switch, do you have to bleed the rear brake? Yes, it’s fairly straight forward. If your not familiar with bleeding: Basically fill brake fluid, pump pedal, hold pressure, crack bleeder - the. Repeat. No special tools needed. The AP3 kit only let in a couple bubbles. Basically bleed until it feels strong or no more air. Share this post Link to post Share on other sites
Flash1034 Posted July 11, 2020 (edited) Thank you, sir. I just ordered the AP3 unit. Where does it attach? I don’t even see it in their picture. Edited July 11, 2020 by Flash1034 Share this post Link to post Share on other sites
Apaden1 Posted July 11, 2020 6 hours ago, Flash1034 said: Thank you, sir. I just ordered the AP3 unit. Where does it attach? I don’t even see it in their picture. Right on! The harness plugs in right in the middle of the cases, between the emissions canister and rear shock. There will be some pictures in the instructions to help you out. Here is a pic of mine! Share this post Link to post Share on other sites
Flash1034 Posted July 12, 2020 (edited) Thanks. Where does the other end attach (the actual switch)? Edited July 12, 2020 by Flash1034 Share this post Link to post Share on other sites
Apaden1 Posted July 12, 2020 3 hours ago, Flash1034 said: Thanks. Where does the other end attach (the actual switch)? The switch replaces the brake banjo bolt with a banjo switch. Basically goes between the brake line and rear master cylinder in place of the banjo bolt. This is how KTM/HQV runs their brake switches. Share this post Link to post Share on other sites
Flash1034 Posted July 12, 2020 Can you please post a pic of how you mounted it on your CRF450L? Share this post Link to post Share on other sites
xpantz Posted July 12, 2020 3 hours ago, Flash1034 said: Can you please post a pic of how you mounted it on your CRF450L? You're looking at it... above. It's pretty easy. Have a look at this video for a better look at what is going on. Share this post Link to post Share on other sites
Flash1034 Posted July 12, 2020 Ahhh, got it. Thanks. Share this post Link to post Share on other sites
Apaden1 Posted July 14, 2020 On 7/12/2020 at 8:48 AM, Flash1034 said: Ahhh, got it. Thanks. Keep me posted on how the install goes for you! Share this post Link to post Share on other sites
Flash1034 Posted July 18, 2020 Install was a piece of cake. Thanks for the great kit. 2 Share this post Link to post Share on other sites
