Keith Marion Posted July 10, 2020 If I remove the fork reflector do I need to add a washer before tightening the lower clamp? Not sure if the bolt would be too long after removing the reflectors. I’ve been searching to try and find this answer and I’m hoping someone can help me out. Share this post Link to post Share on other sites
MVI My Rides (3) Posted July 10, 2020 no spacer needed. you might want to add a tie down loop though.. https://www.amazon.com/gp/product/B07YNMGCBF/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 Share this post Link to post Share on other sites
Shaymer Posted July 10, 2020 5 hours ago, Keith Marion said: If I remove the fork reflector do I need to add a washer before tightening the lower clamp? Not sure if the bolt would be too long after removing the reflectors. I’ve been searching to try and find this answer and I’m hoping someone can help me out. I didn’t, had no isssue. Share this post Link to post Share on other sites
gt750 Posted July 12, 2020 If you are worried about this or other bolts, you could just add a couple of washers. Share this post Link to post Share on other sites
R.L. Sheldrake Posted July 13, 2020 I don't think it will be an issue, as other have said. I went with 40mm bolts for my project for those locations and removed the heavy spacer and the reflector, you could just leave in the heavy spacer/collar and be fine. They are the same ones as the axle pinch bolts if you wanted to go OEM 40mm. Share this post Link to post Share on other sites
