Pw50 taking off on its own! Help!!!
Sounds like ur throttle is sticking or the cable is binding somewhere. Do u know anything about working on a bike? First thing is to trace the cable from the throttle to the carb n see if it's binding up anywhere. If it's not routed correctly it can actually bind and pull the throttle cable as if it turning the throttle by hand. The second thing to do is pull the slide out of the carb, twist the throttle and observe whether the slide snaps back to its fully extended postion.
