ThumperTalk Posted September 11, 2020 What's new for 2021 besides bold, new graphics? "Special" skid plate. More comfy seat. Stronger clutch cover. Solid rear brake disc. Rear brake pedal is safety wired. Anodized orange machined triple clamp WP Xlpor fork w/ spring preload adjustment Quick change front axle pull Supersprox Stealth two-piece aluminum sprocket (shared w/ the Erzbergrodeo edition). Tires are ebay specials, only installed to pass gubberment standards. You'll want to install some rear knobbies here. 2021 KTM 500 EXC-F Six Days Specs ENGINE Type: Single-cylinder four-stroke Displacement: 511cc Bore x stroke: 95 x 72mm Valvetrain: SOHC, 4 valves Fuel System: Keihin EFI w/ 42 mm throttle body Ignition: Keihin EMS Starting: Electric Lubrication: Pressure lubrication w/ 2 oil pumps Transmission: 6-speed Clutch: Wet multi-disc DDS clutch w/ Brembo hydraulics CHASSIS Frame: Chromoly steel central double-cradle, w/ aluminum subframe Subframe: Aluminum Handlebar: Neken, Aluminum w/ 28-22mm diameter Front suspension; travel: Fully adjustable WP Xplor inverted 48mm fork; 12.2 inches Rear Suspension: Linkage-assisted, fully adjustable WP Xplor shock w/ progressive damping; 11.8 inches Wheels: Giant Front wheel: 1.60 x 21” Rear wheel: 2.15 x 18” Tires: Continental TKC 80 Front tire: 90/90 x 21 Rear tire: 120/90 x 18 Front brake: 260mm disc Rear brake: 220mm disc DIMENSIONS and CAPACITIES Wheelbase: 58.3 inches Rake: 26.5 degrees Triple clamp offset: 22mm Seat height: 37.8 inches Ground clearance: 14 inches Fuel capacity: 2.25 gallons Curb weight: 254 pounds Color: Orange 2021 KTM 500 EXC-F Six Days Price: $12,599 MSRP (a grand over the std 500EXC-F). Dealers are expected to see this fall. How about the green? Not seen that before on a KTM and we like it! You? What do you think of the 2021 KTM 500 EXC-F 6 Days? 1 Share this post Link to post Share on other sites
twp8357 Posted September 11, 2020 I have the 2020 Six Days and I have the 2021 on order. Probably late Oct at the earliest says my dealer in Prescott Valley, AZ 2 Share this post Link to post Share on other sites
shrub73 Posted September 12, 2020 The green looks good! 1 Share this post Link to post Share on other sites
Airboss/oc Posted September 12, 2020 glad they went to solid rear disc, better feel like the trials machines Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 12, 2020 2 hours ago, Airboss/oc said: glad they went to solid rear disc, better feel like the trials machines Heavier. 😳 Share this post Link to post Share on other sites
twp8357 Posted September 13, 2020 On 9/12/2020 at 11:19 AM, SteveThe Snakes said: Heavier. 😳 Which rear disk, slotted or solid, do you think would give you more stopping power using a LHRB? I did do some street riding on my 2020 Six Days with my son on my other 500 and a couple of times I did panic stops using just my hands and I had no problem locking up the rear on the pavement. I did get some great use out of the stock tires that I almost threw in the trash....but they work well on the road as I put 2150 miles on them in 6 days. Share this post Link to post Share on other sites
johncr250 Posted September 13, 2020 Great looking bike! Share this post Link to post Share on other sites
Spud786 Posted September 13, 2020 (edited) Ive run the 6days solid disk and the slotted standard disk, My view is the slotted disk has the strongest stopping power, cause the pads bite into the sharp edges of the slots. The solid disk just offers a Longevity improvement, with a tad weaker bite. Edited September 13, 2020 by Spud786 1 Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 13, 2020 3 hours ago, twp8357 said: Which rear disk, slotted or solid, do you think would give you more stopping power using a LHRB? I did do some street riding on my 2020 Six Days with my son on my other 500 and a couple of times I did panic stops using just my hands and I had no problem locking up the rear on the pavement. I did get some great use out of the stock tires that I almost threw in the trash....but they work well on the road as I put 2150 miles on them in 6 days. You should be fine with either on the rear. On supermoto bikes everyone runs stock rear discs and calipers with fat 17” sticky street tires or slicks. It’s the fronts where they change to much larger discs and different brake components on street or track supermoto bikes. Share this post Link to post Share on other sites
Bryan II My Rides (4) Posted September 13, 2020 I've always understood solid disc to be for muddy conditions, where mud can pack in the holes of a cross drilled unit and reduce pad bite. I'm sure that either style and caliper has plenty of power to overcome the available traction the tire might have on any surface, so I can't see any stopping advantage there. 1 Share this post Link to post Share on other sites
Govt Cheese is BACK Posted September 13, 2020 For a company that is normally excellent with visuals, graphics, marketing they've really screwed the pouch this year. The colors are fine but the graphics suck... and he orange frame completely out of place. Completely unattractive. The gray throwback side panels on the regular models and this disgusting color combo makes me sure to never buy a 2021. Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 14, 2020 I’m waiting for the next five year big change. The last big complete new revised bike was the 17’s. I think the 2022’s might be it. I don’t think I’ll bother with the extra six day bling. Share this post Link to post Share on other sites
Mikie1 Posted September 14, 2020 12 hours ago, SteveThe Snakes said: I’m waiting for the next five year big change. The last big complete new revised bike was the 17’s. I think the 2022’s might be it. I don’t think I’ll bother with the extra six day bling. The 2020's were a complete revision. If it's a five year cycle it'll be 2025 till a complete new bike. Maybe by then they'll have the ECU/ fueling figured out a little better. I don't care for the new graphics either. My 2020 XCF-W came with the same "special" skid plate, map/ traction control switch, and black frame. I like it a little better. The fork preload adjusters would be nice, though. 1 Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 14, 2020 35 minutes ago, Mikie1 said: The 2020's were a complete revision. If it's a five year cycle it'll be 2025 till a complete new bike. Maybe by then they'll have the ECU/ fueling figured out a little better. I don’t think the 2020’s were a complete revision at all. The 17’s were and about every five years they change everything. From the frame, wheels complete engine and all. The 2020 was a new head, piston compression and a cam chain slipper. Which is a nice upgrade but not the big one. As far as fueling I doubt it will every be sorted too well with street bike regulations. It might get better stock though. Some of the new street bikes are nowhere as bad as the plated off road enduro bikes. 1 Share this post Link to post Share on other sites
SSPhoto Posted September 14, 2020 2 hours ago, SteveThe Snakes said: I don’t think the 2020’s were a complete revision at all. The 17’s were and about every five years they change everything. From the frame, wheels complete engine and all. The 2020 was a new head, piston compression and a cam chain slipper. Which is a nice upgrade but not the big one. As far as fueling I doubt it will every be sorted too well with street bike regulations. It might get better stock though. Some of the new street bikes are nowhere as bad as the plated off road enduro bikes. 2020 was a big revision, next one is slated for 2023 models. Share this post Link to post Share on other sites
johncr250 Posted September 14, 2020 2 hours ago, SteveThe Snakes said: I don’t think the 2020’s were a complete revision at all. The 17’s were and about every five years they change everything. From the frame, wheels complete engine and all. The 2020 was a new head, piston compression and a cam chain slipper. Which is a nice upgrade but not the big one. As far as fueling I doubt it will every be sorted too well with street bike regulations. It might get better stock though. Some of the new street bikes are nowhere as bad as the plated off road enduro bikes. Sorry but the 2020`s were a complete revision. There were a bunch of changes with the motor including new cylinder head, piston, smog system, exhaust header pipe and muffler etc The 2020 also has a new frame, new subframe, plastics, seat, and wiring upgrades. Also new they have a new fuel injection system, new fuel tank, new smog system, new license plate - tail light assembly, new ECU that changes maps and timing curves in every gear. Forks got new spring rates and dampening too. Share this post Link to post Share on other sites
Airboss/oc Posted September 14, 2020 18 hours ago, Govt Cheese said: For a company that is normally excellent with visuals, graphics, marketing they've really screwed the pouch this year. The colors are fine but the graphics suck... and he orange frame completely out of place. Completely unattractive. The gray throwback side panels on the regular models and this disgusting color combo makes me sure to never buy a 2021. agree this is one of KTM's worst designs Share this post Link to post Share on other sites
johncr250 Posted September 14, 2020 The grey number plates are def ugly, good thing they are cheap to replace with whatever color you like! Share this post Link to post Share on other sites
Govt Cheese is BACK Posted September 14, 2020 3 minutes ago, johncr250 said: The grey number plates are def ugly, good thing they are cheap to replace with whatever color you like! You know they are desperate for ideas when they reach back to the 1990s to retro a design that was fuggly even back then. Lololol Share this post Link to post Share on other sites
SteveThe Snakes My Rides (8) Posted September 14, 2020 (edited) 2 hours ago, johncr250 said: Sorry but the 2020`s were a complete revision. There were a bunch of changes with the motor including new cylinder head, piston, smog system, exhaust header pipe and muffler etc The 2020 also has a new frame, new subframe, plastics, seat, and wiring upgrades. Also new they have a new fuel injection system, new fuel tank, new smog system, new license plate - tail light assembly, new ECU that changes maps and timing curves in every gear. Forks got new spring rates and dampening too. Yes I just read up on them. Much more than I thought previously. But I’m not sure if there weren't even more upgrades from the 16’ to 17’ models especially regarding weight. Time will tell on the 2022 or 2023 models. Edited September 14, 2020 by SteveThe Snakes Share this post Link to post Share on other sites
