I write in hopes that you can help me since no one else seems to be able to. I recently got this 90 dr350 without a carb. I found the factory mikuni carb in the pic below and need to know where the hoses go in relations to the carb.  I know the obvious ones coming from the gas and one leading to the top of the other side but the two circled are where I need help. I think the large brass location circled goes to the bottom of the air box where I have an outlet valve with no hose currently. The little one where the mixture screw seems to have a hose on it in the stock pics but dont see where it goes. Ive tried to find tech specs but cant seem to locate any that help.  Can anyone describe if Im right or off? Any help would be greatly appreciated.
