2016 HUSQVARNA FE350 not starting
Hi all
I'm new so i hope I'm posting in the right area.
I have 2016 husqvarna FE350 that will not start. All I am getting is a tick sound from the solenoid. Fuel pump isn't coming on either.
Things I've tried
Tried a new battery
New voltage regulator
Moving the negative cable
Checked the tip senor
Direct jump between the two screws on the solenoid
Cleaning the contact points on the coil.
Checked all the wires for break points and broken cables
If i roll start she fires up.
Has anyone had this problem and managed to find out what the issue is.
Please help before I find the box of matches.
Edited by jessr50
1 hour ago, Husqvarna1 said:
My 2015 fc 250 had a problem like that. I found that I had to clean the battery terminals and connectors on a regular basis as a build up of corrosion kept the battery from working right
Not the battery, i tried a brand and one out of my mates bikes. Still got nothing. Apparently its the starter itself but doesn't explain why the fuel pump isn't still prime. Anyway will order in a new starter and replace it.
Have you applied 12v directly to the starter
Rarely the starter, usually the starter relay
  • Helpful 1
  • 2 months later...
I did, still wouldn't turn over. Guessing its the brushes. New starter was sent to the forwarding company on Thursday so hopefully I'll have it here in Zambia in two weeks or so.
