how to relocate your key to the RH side of the front turn signal
1/4" thick aluminum plate
3" long
1 1/2" wide
made this at work on a slow day after hours
removed OEM key holder
I had to do a bit of trimming on the plastic on the RH side above where the signal bolts to the head light housing how it trimmed it was by heating up a razor blade and cutting slowly trimming it back to fit nice and drilling and die grinding it down to fit the key housing in the plate i made. looks like i drilled a 3/8" hole to bolt it with the signal light just have to unplug the light and unbolt the light and remove the washer and nut and install the key bracket in on the signal light bolt and install the washer and nut. and install key cylinder and adjust where you would like the key to sit for off and on
Nice.  Or you could just buy a stock KTM OEM plastic bracket for a ‘16 or earlier model for $3.80.
Edited by Gflo
  • Haha 2
My buddy has that on his older KTM 500 (or something like that), makes it nice and accessible when you lose your key in the woods and you have to field modify your switch so you can keep riding. Life can be an adventure...
