KTM Rear Brake Plunger Removal
Does anyone know how to remove the rear brake “piston/plunger” that drives the movement of fluid in the master cylinder? Trying to replace mine as the seals are bad but for the life of me I cannot get it out. It is not threaded, there is no c-clip, it won’t fall out the bottom no matter how much I tap the sides, and I’ve even tried blowing compressed air down into the small hole at the bottom of the cylinder to see if it would blow out and it still wouldn’t budge. It will slide up just like it’s supposed to but will not come out the bottom for removal. Anyone have any tips on how I can remove this?
Bike is a 2014 KTM 350 XC-F
Thanks in advance!!!
Photo is of the bottom of the master cylinder.
Edited by MotoXRacer_19
