How’s this piston and cylinder look?
I’m doing my first top end and I think I might need new plating, it seems to be partly worn on the exhaust bridge.
I can only feel a few light scratches with my fingernail on the exhaust side of cylinder.
I also know you can see how the engine in running by the carbon patterns on the piston. Does mine show anything?
Edited by Aaron C.
your choices are.  PowersealUSA. USCHROME. MILLENIUM Technologies.
I have no experience with any of them, so I can't say brother.
and there are likely others, but those are the 3 that I know of.
  • Helpful 1
46 minutes ago, Aaron C. said:
I was expecting that Answer, you know anyone who does good work?
I will say that I am a PowerSealUSA.com only user. Nobody else has ever compared except for Langcourt in the USA, but they are no longer as of 4 years ago I believe.
  • Helpful 1
Been using Powerseal exclusively for many years, always a good result.  I will leave it right there.  At this time they have done at least 500 top end re-linings for me.  Most were bore and re-lines but many were just re-lining.
Edited by wallybean
1 minute ago, Aaron C. said:
Wow, guess I know where to go now👍
Make sure you use a good piston kit, don't scrimp to save a few bucks.  Do that and you will get many more hours of enjoyment out of the motor.
I was planning on ordering a wisco pro-lite piston. Do I sent it with the cylinder for them to make sure the clearance is right?
Edited by Aaron C.
Yes you send it along with a cylinder..
Why no Langcourt? I had them do a YZ 250 cylinder years ago.
