Raztech Powersports Posted January 6 Hope this video helps and thanks for watching! Quote Share this post Link to post Share on other sites
GavMac78 Posted January 6 (edited) Thanks for the video. It does look super clean. The one suggestion that I'd make, unless I missed something, is to have some kind disconnect between the light and the switch. I don't take my number plate off very often but when I do, I need it completely out of the way. Like any kind of fork rebuild or if I just happened to tweak the forks and need to straighten them back up. Or a handlebar swap. I had to do this a few times on both a 150f and a 230f. They are basically the same bike. I needed the number plate off and out of the way both times. The upper triple bolts are underneath the number plate on my 230's. There is not nearly enough clearance to fit a socket, and definitely not a torque wrench. Unless I missed it, it looks like the wire off the light is one piece that goes directly to the switch. Again, it looks like the light, plate and switch are all permanently connected together. Am I wrong? I get the watertight seal but I might just do waterproof butt connectors between the light and the switch. Same as you'd find on the Ignition switch. Edited January 6 by GavMac78 Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 6 11 hours ago, GavMac78 said: Thanks for the video. It does look super clean. The one suggestion that I'd make, unless I missed something, is to have some kind disconnect between the light and the switch. I don't take my number plate off very often but when I do, I need it completely out of the way. Like any kind of fork rebuild or if I just happened to tweak the forks and need to straighten them back up. Or a handlebar swap. I had to do this a few times on both a 150f and a 230f. They are basically the same bike. I needed the number plate off and out of the way both times. The upper triple bolts are underneath the number plate on my 230's. There is not nearly enough clearance to fit a socket, and definitely not a torque wrench. Unless I missed it, it looks like the wire off the light is one piece that goes directly to the switch. Again, it looks like the light, plate and switch are all permanently connected together. Am I wrong? I get the watertight seal but I might just do waterproof butt connectors between the light and the switch. Same as you'd find on the Ignition switch. Yes I wired it directly just to make it as clean as possible. If I had some high end connectors, I probably would have used them tho. Not a fan of bullet connectors. Theres enough wire to put the number plate aside if I need to service the front forks or triple trees. Quote Share this post Link to post Share on other sites
Chuck. My Rides (3) Posted January 6 Nice neat install. How many watts of power does it use? Cycle Terminal has connectors. I used a 6 LED bar on my XR, it has 2 spot LEDs and 4 flood LEDs, only 2 wires so no hi/lo. It draws 23 watts so not much load on the XRs headlight system. It does throw a lot of light that I estimate at about 5-6 times more light than a XR 35watt headlight bulb. Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 7 10 hours ago, Chuck. said: Nice neat install. How many watts of power does it use? Cycle Terminal has connectors. I used a 6 LED bar on my XR, it has 2 spot LEDs and 4 flood LEDs, only 2 wires so no hi/lo. It draws 23 watts so not much load on the XRs headlight system. It does throw a lot of light that I estimate at about 5-6 times more light than a XR 35watt headlight bulb. Very nice setup! Like the Spot / flood combo. My Rigid Flood is a 20w draw. 1 Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 9 One note on the honda crf 150/230... if you leave the key on, it drains the battery... if only there was a power light or neutral light! Looks like I have another project! Quote Share this post Link to post Share on other sites
Confederate My Rides (2) Posted January 9 I have my key switch removed and straight wired for about ten years now and have no battery drain whatsoever. The switch is a ground switch. Have had the same Shorai battery for about seven years, never had a problem with battery drain. Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 9 On a crf 150f? Its a common problem on these crf 150s. A bunch of my friends have them as well and we all deal with this dumb issue 😕 Quote Share this post Link to post Share on other sites
Confederate My Rides (2) Posted January 9 On a 230f Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 10 So strange.. it must have a different harness because the 150f drains to nothing. Quote Share this post Link to post Share on other sites
Chuck. My Rides (3) Posted January 12 On 1/9/2021 at 7:56 AM, Raztech Powersports said: One note on the honda crf 150/230... if you leave the key on, it drains the battery... if only there was a power light or neutral light! Looks like I have another project! Two options: 1. Build a circuit with a relay that only closes when the engine is running, the relay controls power from the battery to the light switch. 2. Begin only using the key switch to shut off the engine, only use the kill button for emergencies. #2 will work with the 230 key switch which has 4 wires/2 circuits, one for ignition kill and one for power. I don't know if the 150 kill switch is the same. 1 Quote Share this post Link to post Share on other sites
Raztech Powersports Posted January 14 On 1/12/2021 at 10:41 AM, Chuck. said: Two options: 1. Build a circuit with a relay that only closes when the engine is running, the relay controls power from the battery to the light switch. 2. Begin only using the key switch to shut off the engine, only use the kill button for emergencies. #2 will work with the 230 key switch which has 4 wires/2 circuits, one for ignition kill and one for power. I don't know if the 150 kill switch is the same. Yeah the kill button gets you because the bike is still “on” 🙃 Quote Share this post Link to post Share on other sites
