Rob Laughton Posted January 6 Hello, It's my first post here, although I've searched the forums many times. I'm working on an 1987 XL 185 that had been sitting many years. I've tanked the carb. Should you be able to blow through the idle jet? The side holes are clear, but I can't blow through the whole jet. I've tried using welding tip cleaners, but can't get through. It seems to me if it's drilled, I should be able to blow through. PS, I found a new trick; I heated the jets briefly with MAP gas torch, and cooled. The residual fuel tar turned to black dust and fell out. I guess I should be careful, as I assume the brass melts easily. If anyone could comment on the idle jet passages, that would be great. Thanks, Rob in Ontario Share this post Link to post Share on other sites
bimbamboom My Rides (4) Posted January 6 1 hour ago, Rob Laughton said: Hello, It's my first post here, although I've searched the forums many times. I'm working on an 1987 XL 185 that had been sitting many years. I've tanked the carb. Should you be able to blow through the idle jet? The side holes are clear, but I can't blow through the whole jet. I've tried using welding tip cleaners, but can't get through. It seems to me if it's drilled, I should be able to blow through. PS, I found a new trick; I heated the jets briefly with MAP gas torch, and cooled. The residual fuel tar turned to black dust and fell out. I guess I should be careful, as I assume the brass melts easily. If anyone could comment on the idle jet passages, that would be great. Thanks, Rob in Ontario Usually with low speed jets that are that clogged I don’t mess around and just order a new one. 3 1 Share this post Link to post Share on other sites
oldman My Rides (8) Posted January 7 2 hours ago, bimbamboom said: Usually with low speed jets that are that clogged I don’t mess around and just order a new one. Ditto what bimbamboom said Share this post Link to post Share on other sites
Jackrides Posted January 7 Add a #60 - #80 drill bit setto your collection, but be damn careful with it. Tiny idle jet holes won't pass much when clear. might be more visible if you blew into it with all the other holes under water. Share this post Link to post Share on other sites
Randy300XC Posted January 7 The slow jet (idle jet) metering hole is smaller than the end hole that you see when looking at the jet. Very small and recommend replacement. Share this post Link to post Share on other sites
Roslyn Rider Posted January 7 To quote master mechanic Ken Krist, in who's tutorage I worked for many years: "Never put anything harder than your polish sausage in a jet." Drill bits and welding tip cleaners are a no-no. If you can't clear jets with compressed air they need to be replaced. 2 Share this post Link to post Share on other sites
hondamac Posted January 8 I've never replace jets, I've been able to clean them. Look through the main jet the pilot jet should look the same with a much smaller hole. You need to be able to find a piece of wire smaller than that hole to work in there. Wire from fine wire wheels, brushes held in vice grips is an option. Soak the jet in carb cleaner in a small glass jar with the lid on over night and try again. When you get the wire through roll the jet on the wire until it feels smooth. If your older than 18 get a good magnifying glass to look through the opening. It should be round. If in doubt spend the money on a new jet. 1 Share this post Link to post Share on other sites
DaveW2 Posted January 8 You could try soaking it for an hour in 9% hydrochloric acid (toilet bowl cleaner - sometimes it comes at 23% and should be diluted). Share this post Link to post Share on other sites
hondaxr650rrrr Posted January 8 I would never use a torch cleaner on a brass jet. They can ream out the hole. I always use a bristle from a hand wire brush, as they are smooth sided and ill not cause damage when used properly. 1 Share this post Link to post Share on other sites
jeffrey sisti Posted January 8 I agree with Honda650rrr, torch tip cleaners can change the jet size if your not careful, a strand of wire from a wire brush is good Share this post Link to post Share on other sites
Naaasty Posted January 8 The wire that attaches ID tags works pretty good depending on how clogged the jet is. Break loose a few $$$ and buy a new one! Also, if you carb dipped the main body, spray it out with a good carb spray such as Berrymans. If you did not take out the needle seat check the "O" ring and replace it too as the carb dip ruined it. Share this post Link to post Share on other sites
bweighmaster Posted January 8 Guitar , piano wire , propane torch , only things I have ever used . Has worked well on every carb ever cleaned over the last 60 yrs. WalMart carb cleaner spray is just as good as anything else and is very budget minded ... Share this post Link to post Share on other sites
Rob Laughton Posted January 8 Wow! I'm really impressed with the number of replys! Thank you! What a great forum! Lots of good advise here to think over. It's great to learn stuff. I was unable to clean the slow jet, and when I used compressed air in the carb body I lost the O ring and washer from the idle mixture hole. I didn't know there were bits still in the hole. So, new parts are on the way. I should have checked the parts diagram before rebuild. I'll have to hunt for a Polish sausage tool....LOL Rob Share this post Link to post Share on other sites
Doogee57 Posted January 8 1 hour ago, Rob Laughton said: should have checked the parts diagram before rebuild. Good idea..... Share this post Link to post Share on other sites
Rob Laughton Posted January 9 Thank you all. New jets are in, and the bike purrs Vimeo video here: https://vimeo.com/manage/498690147/distribution?utm_campaign=28749&utm_medium=vimeo-cliptranscode-201504&utm_source=email Rob Share this post Link to post Share on other sites
foxtrot722 Posted January 10 On 1/7/2021 at 9:35 PM, jeffrey sisti said: I agree with Honda650rrr, torch tip cleaners can change the jet size if your not careful, a strand of wire from a wire brush is good This is correct, and the strand of wire from a wire brush is what I have used many time with success. Share this post Link to post Share on other sites
Doogee57 Posted January 10 7 hours ago, foxtrot722 said: This is correct, and the strand of wire from a wire brush is what I have used many time with success. Done exactly this for years. It works. On 1/7/2021 at 6:24 PM, hondamac said: . You need to be able to find a piece of wire smaller than that hole to work in there. Wire from fine wire wheels, brushes held in vice grips is an option. Soak the jet in carb cleaner in a small glass jar with the lid on over night and try again. When you get the wire through roll the jet on the wire until it feels smooth. If your older than 18 get a good magnifying glass to look through the opening. It should be round. If in doubt spend the money on a new jet. Just like this. Share this post Link to post Share on other sites
foxtrot722 Posted January 10 1 hour ago, Doogee57 said: If your older than 18 get a good magnifying glass to look through the opening. It should be round. If in doubt spend the money on a new jet. Dead on correct Share this post Link to post Share on other sites
TexanCRF-250R Posted January 11 (edited) Strip off the plastic from a bread tie and use that wire to clean pilot jets. It works. I understand why some buy new jets but i usually don't want to wait 3-4 days for the new jets. So I clean mine. Also, use the original mikuni or keihin jet if at all possible and avoid the chinese jets that comevin most rebuild kits, particularly if you are the type that worries about changing jet bore with a torch cleaner. Glad the OP got it cleaned up and running. Edited January 11 by TexanCRF-250R 1 Share this post Link to post Share on other sites
Jackrides Posted January 13 Use a copper wire strand on jets if you must. Do Not use steel, it is much more likely to scratch or enlarge the jet hole. Also, pull the wire thru a 400 or smaller grit emory paper to remove any burr on the end of the wire. At those tiny sizes, a burr couldn't be seen by many people without a loupe. 1 Share this post Link to post Share on other sites
