Technical touch settings list
16 hours ago, Texask5 said:
Any one seen 2021 list? I've got the 2020 and 2019.
They stopped posting them on the website. Of you want a specific model you can call and ask the nice lady to email it to you.
I just opened up a 21 300 factory edition, and it was exactly as stated.
  • 2 months later...
I've studied the data sheets and compared yamaha wr.s stacks to my TM en 300  bike with kyb forks. The wr.s stacks are alot stiffer compared.
My midvalve has a drilled 1.2 mm bleed stock. Can anyone comfirm if the wr also has a bleed in the midvalve?
Other than that I think the forks is the same.
  • 4 weeks later...
  • 3 weeks later...
  • 3 months later...
8 hours ago, YammerHammer191 said:
I can't find the 2019 any where. I was specifically looking for the 250FX specs. Do you happen to have a link?  🙂
I have a .pdf version of the 2019 list that has been posted on the forum a while back but the YZ250FX does not appear in it.
Edited by mlatour
3 hours ago, mlatour said:
A member posted these from his 2018 YZ250FX a while back, once disassembled you could compare with your 2019:
I found that information on here already, but thank you! I was just curious about the differences, if any, between the two bike setups is all.
