Lincoln Posted Wednesday at 07:13 PM For some reason I started it and it just rev bombed I have been looking taking the throttle apart I took the needle out of the carb and it’s still doing it anyone have a idea I’m so confused right now. Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 08:33 PM check the trottle cable end piece that goes into the slide, make sure it is fully seated in the slide or you could have the problem you previously stated. lastly check your throttle cable and make sure it isnt bound up somewhere in the bike. let us know if that didnt fix it Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 08:34 PM What do you mean the throttle cable end peice Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 08:35 PM there is a little metal piece on the end of the trottle cable that goes through the top of the carb and down into the base of the slide where the needle comes out, if you have a pwk carb it is different, what carb do you have? Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 08:40 PM Where do I find what carb I have Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 08:41 PM I have this carb on it Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 08:47 PM thank you, now i need you to unscrew the cap on the top of the carb where the cable comes into the carb, after you unscrew it the slide should come out easily while still on the throttle cable, look at the bottom of the slide and there should be a slot for the end of the cable to fit into. if it is in the slot and fully recessed into the slide then it is properly inserted. after trying that i would recommend you make sure you have enough slack in the throttle cable to allow the slide body to rest against the base of the carb. thry my first commendation, if you need a visual representation then i would look on youtube for "pitbike carb slide install" Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 08:56 PM Ok thanks a lot I will check it out and see if it works. 1 Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 09:08 PM I think the problem is that I don’t have enough cable in the slide. How would I get more? Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:13 PM there should be an adjuster on the throttle tube where you can screw it in or out to add or take away slack. this might help Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 09:22 PM Did the thing with the throttle still is really high in rmps Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:28 PM either you need a new cable, or you can trim the cable housing down a little bit by bit till it fits, second option can ruin a cable if done poorly, you gave the cable as much slack as possible right? just double checking Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 09:30 PM Is this right or am I doing something stupied Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:33 PM (edited) im talking about where the throttle comes through. see the nob on the outside of the throttle tube.has the black plastic then a metal wheel in the upper leftof the pic, thats where you adjust the throttle slack Edited Wednesday at 09:33 PM by Randy K Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:34 PM (edited) loosen the metal disc and twist the end farther in to give more slack Edited Wednesday at 09:34 PM by Randy K Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 09:36 PM This peice Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:43 PM yah thats it, looks like it is as short as it can get, your going to need to cut the throttle cable housing down a little bit to get that cable to work, there usually is an adjuster on the top of the carb as well that can give you more slack. it is under the rubber bit on top of the carb cap i asked you to remove earlier. if there isnt any slack there then either order a new cale or if your good with tools you can cut the throttle cable tube around the braided cable back a half inch and see if that fixes it. just dont cut the braided cable or your out of luck Quote Share this post Link to post Share on other sites
Lincoln Posted Wednesday at 09:46 PM Ye I’m not very good with dirt bikes externals put man you get me into that motor I’m a expert with that stuff so maybe I will have one of my friends take a look at it it really sucks because I just was riding it yesterday and it was perfectly fine man I just wanna ride and that’s all that goes threw my head out that’s I will let you know if I need anything else. Quote Share this post Link to post Share on other sites
Randy K Posted Wednesday at 09:54 PM if it worked before then you shouldnt have an issue, maybe rerun the throttle cable and make sure it isnt pinching in the top of the carb, i spray dirtbike chain lube into mine and never have a sticking cable, hope you can have a friend fix it for you man, sorry i couldn't help more Quote Share this post Link to post Share on other sites
