2011 athena yz125 gaskets
The Athena kit will have a larger cylinder & head gasket to account for the overbore, if you went that way. But you can order overbore gaskets from other sources as well.
I just got one for a 2002, and it came with every gasket you can think of. Head, cylinder, PV cover, PV actuator cover, PV shaft seal, etc. It may seem pricey at first, but it's worth it I believe.
It also came with a rubber and a paper gasket for the cylinder.
Edited by redwood thumper
