1999 Honda CR80 won’t start please help
I have been having the hardest time trying to get this thing to start. I replaced the crank shaft, connecting rod, and piston. No scratches in the jug. I have 110psi of compression. The starter coil has .5 ohms of resistance. Replaced the spark plug and tested for spark. Cleaned the carb and trued starter fluid. Any suggestions?
4 minutes ago, Jack Aman said:
I didn’t think you could change the timing?
He may be talking about ignition timing, just google 2 stroke ignition timing, look into it a little, and see if you can find anything helpful
