Klutch5000 Posted Monday at 05:27 PM See attached pic, circled in red. Not sure what they trying to say? Share this post Link to post Share on other sites
mode12 Posted Monday at 05:31 PM The little brass screw will turn with the knob. anti-clockwise is the same as counter clockwise. that’s how I read that. 2 Share this post Link to post Share on other sites
redhurricane Posted Monday at 07:04 PM Inner brass screw is low speed compression, large red knob is high speed. clockwise on either increases damping, counter(anti) clockwise reduces damping. Something of note, the HS adjuster (red knob) is not very linear in adjustment, more like an on/off reaction no matter how far you go in either direction. There are better aftermarket solutions for that downfall if it's something you want to pursue. Share this post Link to post Share on other sites
Klutch5000 Posted Monday at 07:29 PM 21 minutes ago, redhurricane said: Inner brass screw is low speed compression, large red knob is high speed. clockwise on either increases damping, counter(anti) clockwise reduces damping. Something of note, the HS adjuster (red knob) is not very linear in adjustment, more like an on/off reaction no matter how far you go in either direction. There are better aftermarket solutions for that downfall if it's something you want to pursue. I do know how they work. I was just thrown off by what I circled in red. Was thinking the same as mode12 pointed out about the low speed rotates when turning the high speed knob. I did have the suspension valved and sprung for my riding terrain and weight. Not sure if it addresses the high speed being more of an on/off thing tho. Share this post Link to post Share on other sites
KRAYNIAL My Rides (7) Posted Monday at 07:33 PM They work independently, but rotate together when turning the high speed knob. 2 Share this post Link to post Share on other sites
redhurricane Posted Monday at 07:50 PM Krannie explained this better than I did. Low speed rotates with high speed, but is not changing the setting on LS when you move HS. He and I both have since replaced the stock compression adjuster with the Lainer version and it is much more linear in adjustment. 2 Share this post Link to post Share on other sites
Klutch5000 Posted Monday at 10:29 PM Ok good to know. Thanks. I'll be able to test once snow melts here. Share this post Link to post Share on other sites
Doc Brown Posted Tuesday at 09:39 AM That happens when Italians think they can speak English. 🤠 2 Share this post Link to post Share on other sites
Odysseus Posted Tuesday at 05:07 PM (edited) 7 hours ago, Doc Brown said: That happens when Italians think they can speak English. 🤠 Your doing it wrong Doc.You have to read it aloud using rising and falling singsong tones while moving your arms like like a maestro conducting a Wagnerian opera. Edited Tuesday at 05:08 PM by Odysseus 1 Share this post Link to post Share on other sites
Hannibal Babar Posted Tuesday at 09:07 PM low or high speed, be ready to enjoy italian women ! Believe me !! 1 1 Share this post Link to post Share on other sites
Doc Brown Posted Tuesday at 09:44 PM 35 minutes ago, Hannibal Babar said: low or high speed, be ready to enjoy italian women ! Believe me !! What are you trying to tell me mate? Some years ago I was in Italy at least 4 times a year. I do believe you 🤠 Share this post Link to post Share on other sites
Chicken-N-Waffles My Rides (3) Posted yesterday at 12:06 AM 2 hours ago, Doc Brown said: What are you trying to tell me mate? Some years ago I was in Italy at least 4 times a year. I do believe you 🤠 I'm headed to Florence for a destination wedding, then taking a 5 day ride into the mountains on a rented Duc, are you local to the area? 2 Share this post Link to post Share on other sites
dieseleveryday My Rides (7) Posted yesterday at 02:55 AM 17 hours ago, Doc Brown said: That happens when Italians think they can speak English. 🤠 The Italian tractor MFG's are even worse the axles have a "mouse hole" in them to make the axle wet with grease. is their way of saying there's an inspection cover to fill the axle with gear lube 1 Share this post Link to post Share on other sites
Doc Brown Posted 9 hours ago 17 hours ago, Chicken-N-Waffles said: I'm headed to Florence for a destination wedding, then taking a 5 day ride into the mountains on a rented Duc, are you local to the area? Nope, I am further north in Austria. But I used to be member of the Lancia Delta Integrale Club in Treviso and also was member of a vintage car club in Francenigo. Share this post Link to post Share on other sites
Doc Brown Posted 9 hours ago 15 hours ago, dieseleveryday said: The Italian tractor MFG's are even worse the axles have a "mouse hole" in them to make the axle wet with grease. is their way of saying there's an inspection cover to fill the axle with gear lube The Spanish (I own a GasGas, a real one not a KTM Gas) are even worse. Reading their owners manuals is better than watching a comedy.... 🙂 Share this post Link to post Share on other sites
